Ir para o conteúdo principal
HP Pavilion dv2700 Hard Drive Replacement
O que você precisa
  1. HP Pavilion dv2700 Hard Drive Replacement, Hard Drive: passo 1, imagem 1 %32
    • To remove the battery, pull the tab to the left and lift the battery from the computer.
  2. HP Pavilion dv2700 Hard Drive Replacement: passo 2, imagem 1 %32
    • Using a #0 Phillips Head screwdriver, unscrew the hard drive cover.
    • The screws cannot be removed from the cover.
    • To remove the cover, lift up and to the left.
  3. HP Pavilion dv2700 Hard Drive Replacement: passo 3, imagem 1 %32
    • Using a #0 Phillips Head screwdriver, remove the screws holding the hard drive in place.
    • These are the two screws located on the right side of the hard drive.
  4. HP Pavilion dv2700 Hard Drive Replacement: passo 4, imagem 1 %32 HP Pavilion dv2700 Hard Drive Replacement: passo 4, imagem 2 %32
    • Lift the tab connected to the hard drive in order to remove it.
    • The hard drive may be difficult to remove by grabbing the tab. In this case, use the spudger to gently pry it from the computer.
Conclusão
Jared Opperman
Membro desde: 09/24/15
161 Reputação
Autoria de 1 guia
Equipe
Texas Tech, Team 22-6, Rauch Fall 2015 Membro de Texas Tech, Team 22-6, Rauch Fall 2015
TTU-RAUCH-F15S22G6
Membros da 3
Autoria de 2 guias
Um comentário
Hi, I have a seagate hard drive that was mounted on a hp pavillon dv series computer. I only have the hard disk and I can not find any serial adapter that can be connected to the hard disk connector. I saw on amazon and ebay but I did not find anything. Can you help me? Thank you!
L. S. - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 21
Duração total: 3,015
