Ir para o conteúdo principal
HP Pavilion dv2000 Wireless Card Replacement
O que você precisa
  1. HP Pavilion dv2000 Wireless Card Replacement, Wireless Card: passo 1, imagem 1 %32 HP Pavilion dv2000 Wireless Card Replacement, Wireless Card: passo 1, imagem 2 %32
    • Make sure your computer is powered down and unplugged from the charger before removing any components.
    • Locate and unscrew the single 3.8mm screw holding the wireless card casing in place.
    • Lift up and remove the wireless card casing.
    • The 3.8mm screw will remain in the wireless card casing after you unscrew it.
  2. HP Pavilion dv2000 Wireless Card Replacement: passo 2, imagem 1 %32 HP Pavilion dv2000 Wireless Card Replacement: passo 2, imagem 2 %32
    Ferramenta utilizada neste passo:
    • Use a pair of tweezers to remove the three antennas from their sockets.
    • Remove the antennas by the contacts connected to the socket, the crimps connecting the wires and the sockets are delicate and are easily damaged.
  3. HP Pavilion dv2000 Wireless Card Replacement: passo 3, imagem 1 %32 HP Pavilion dv2000 Wireless Card Replacement: passo 3, imagem 2 %32 HP Pavilion dv2000 Wireless Card Replacement: passo 3, imagem 3 %32
    Phillips #00 Screwdriver
    $5.49
    • Remove the two 3.8mm screws holding down the wireless card with your Phillips #00 Screwdriver.
    • Gently pull out your wireless card from its top side to remove it from its holding.
Conclusão
3 outras pessoas executaram este guia.
Erik Muniz
Membro desde: 09/09/14
820 Reputação
Autoria de 3 guias
Equipe
CSU Fullerton, Team 2-3, Bruce Fall 2014 Membro de CSU Fullerton, Team 2-3, Bruce Fall 2014
CSUF-BRUCE-F14S2G3
3 Membros
Autoria de 4 guias
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 15
Ao todo: 2,340
