Ir para o conteúdo principal
HP Pavilion dv2000 Keyboard Replacement
O que você precisa
  1. HP Pavilion dv2000 Keyboard Replacement, Keyboard: passo 1, imagem 1 %32 HP Pavilion dv2000 Keyboard Replacement, Keyboard: passo 1, imagem 2 %32
    • Make sure your computer is powered down and unplugged from the charger before removing any components.
    • Remove the ten 8.9mm screws (underneath where the battery would be) holding the keyboard and bezel in place.
  2. HP Pavilion dv2000 Keyboard Replacement: passo 2, imagem 1 %32 HP Pavilion dv2000 Keyboard Replacement: passo 2, imagem 2 %32
    • Flip the computer over to the front (keyboard-side up).
    • Gently pop the bezel off by reaching underneath it and pulling up.
    • If you are doing this for the first time, the bezel may require you to exert a little bit more force to remove it.
  3. HP Pavilion dv2000 Keyboard Replacement: passo 3, imagem 1 %32 HP Pavilion dv2000 Keyboard Replacement: passo 3, imagem 2 %32
    • The keyboard is held in by three small tabs near the bezel of the computer. Lifting the bezel frees the three tabs.
    • If you are removing the keyboard, the tabs will require a bit more upward force to pull away from the keyboard.
    • Remove the ribbon connecting the keyboard to the computer by pulling back on the ribbon (away from the track pad).
Conclusão
6 outras pessoas executaram este guia.
Erik Muniz
Membro desde: 09/09/14
820 Reputação
Autoria de 3 guias
Equipe
CSU Fullerton, Team 2-3, Bruce Fall 2014 Membro de CSU Fullerton, Team 2-3, Bruce Fall 2014
CSUF-BRUCE-F14S2G3
3 Membros
Autoria de 4 guias
1Comentário do guia
Many THANKS Erik
I am a computer imbecile. I own a hp pavilion dv2000 that is about 10-12 years old.
I may now be able to FIX it and not have to buy a whole new one
phillip james
Phillip James - Responder
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 14
Ao todo: 2,991
