Ir para o conteúdo principal
HP Pavilion dv2000 Hard Drive Replacement
O que você precisa
  1. HP Pavilion dv2000 Hard Drive Replacement, Hard Drive: passo 1, imagem 1 %32 HP Pavilion dv2000 Hard Drive Replacement, Hard Drive: passo 1, imagem 2 %32
    Ferramenta utilizada neste passo:
    Phillips #00 Screwdriver
    $5.49
    • Flip your computer over, so that the underside of your computer is facing upward.
    • Make sure your computer is powered down and unplugged from the charger before removing any components.
    • Locate the hard drive casing on the bottom-right corner of your flipped computer.
    • Remove the two 3.8mm screws with your Phillips #00 Screwdriver and carefully lift up and remove the hard drive casing.
    • Screws on hard drive casing will remain in casing after being unscrewed.
  2. HP Pavilion dv2000 Hard Drive Replacement: passo 2, imagem 1 %32 HP Pavilion dv2000 Hard Drive Replacement: passo 2, imagem 2 %32 HP Pavilion dv2000 Hard Drive Replacement: passo 2, imagem 3 %32
    Phillips #000 Screwdriver
    $5.49
    • After you lift off the hard drive casing, using your Phillips #000 Screwdriver, remove the two 3.6mm screws located on the right side of the hard drive.
    • Using your fingers, carefully lift the lower right corner of your hard drive until it is removed from its housing.
Conclusão
7 outras pessoas executaram este guia.
Erik Muniz
Membro desde: 09/09/14
820 Reputação
Autoria de 3 guias
Equipe
CSU Fullerton, Team 2-3, Bruce Fall 2014 Membro de CSU Fullerton, Team 2-3, Bruce Fall 2014
CSUF-BRUCE-F14S2G3
3 Membros
Autoria de 4 guias
Um comentário
You didnt mention this HDD has a different SATA connector , I cant find it in the market, instead of plug in , this one is for pressing down only
tml215 - Responder
Comentar
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 17
Ao todo: 4,404
