Ir para o conteúdo principal
HP Pavilion dm4-1265dx Hard Drive Replacement
O que você precisa
  1. HP Pavilion dm4-1265dx Hard Drive Replacement, Battery: passo 1, imagem 1 %32
    • Flip the laptop over so the bottom is facing up.
  2. HP Pavilion dm4-1265dx Hard Drive Replacement: passo 2, imagem 1 %32 HP Pavilion dm4-1265dx Hard Drive Replacement: passo 2, imagem 2 %32 HP Pavilion dm4-1265dx Hard Drive Replacement: passo 2, imagem 3 %32
    • Push the sliding lock to release the battery.
    • Remove the battery by lifting it away from the device.
  3. HP Pavilion dm4-1265dx Hard Drive Replacement, Back Panel: passo 3, imagem 1 %32 HP Pavilion dm4-1265dx Hard Drive Replacement, Back Panel: passo 3, imagem 2 %32
    • Orient the device so that the empty battery port is closest to you.
    • Loosen the two captive screws holding the back panel in place using a Phillips #0 screwdriver.
  4. HP Pavilion dm4-1265dx Hard Drive Replacement: passo 4, imagem 1 %32 HP Pavilion dm4-1265dx Hard Drive Replacement: passo 4, imagem 2 %32 HP Pavilion dm4-1265dx Hard Drive Replacement: passo 4, imagem 3 %32
    • Pull back and lift the back panel to remove it from the device.
  5. HP Pavilion dm4-1265dx Hard Drive Replacement, Hard Drive: passo 5, imagem 1 %32 HP Pavilion dm4-1265dx Hard Drive Replacement, Hard Drive: passo 5, imagem 2 %32 HP Pavilion dm4-1265dx Hard Drive Replacement, Hard Drive: passo 5, imagem 3 %32
    • Loosen the single captive screw holding the hard drive cover in place using a Phillips #0 screwdriver.
    • Lift the hard drive cover away and up to remove.
  6. HP Pavilion dm4-1265dx Hard Drive Replacement: passo 6, imagem 1 %32 HP Pavilion dm4-1265dx Hard Drive Replacement: passo 6, imagem 2 %32 HP Pavilion dm4-1265dx Hard Drive Replacement: passo 6, imagem 3 %32
    • Lift the hard drive out of the device from the connector side.
    • Grasp the connector and pull it out of the hard drive.
    • Remove the hard drive from the laptop.
Conclusão
Matthew Walter
Membro desde: 03/29/22
109 Reputação
Autoria de 1 guia
Equipe
Casper College, Team 1-1, Lareau Spring 2022 Membro de Casper College, Team 1-1, Lareau Spring 2022
CASC-LAREAU-S22S1G1
Membros da 4
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 14
Duração total: 364
