Ir para o conteúdo principal
HP Pavilion dm1z-3000 Cooling Fan Replacement
O que você precisa
  1. HP Pavilion dm1z-3000 Cooling Fan Replacement, Cooling Fan: passo 1, imagem 1 %32
    • Shut down the computer.
    • Disconnect all external devices and cables from the compute.
  2. HP Pavilion dm1z-3000 Cooling Fan Replacement: passo 2, imagem 1 %32 HP Pavilion dm1z-3000 Cooling Fan Replacement: passo 2, imagem 2 %32 HP Pavilion dm1z-3000 Cooling Fan Replacement: passo 2, imagem 3 %32
    • Find the black sliding tab next to where the battery is located.
    • Slide the black tab until you hear a click.
    • Gently remove the battery.
  3. HP Pavilion dm1z-3000 Cooling Fan Replacement: passo 3, imagem 1 %32 HP Pavilion dm1z-3000 Cooling Fan Replacement: passo 3, imagem 2 %32
    • Gently lift the back panel of the laptop from where the battery was located.
  4. HP Pavilion dm1z-3000 Cooling Fan Replacement: passo 4, imagem 1 %32 HP Pavilion dm1z-3000 Cooling Fan Replacement: passo 4, imagem 2 %32
    • Remove the three screws with a #00 Phillips screwdriver.
  5. HP Pavilion dm1z-3000 Cooling Fan Replacement: passo 5, imagem 1 %32 HP Pavilion dm1z-3000 Cooling Fan Replacement: passo 5, imagem 2 %32 HP Pavilion dm1z-3000 Cooling Fan Replacement: passo 5, imagem 3 %32
    • Once the screws have been taken out gently lift up the fan and remove it from the device.
Conclusão
John Morillas
Membro desde: 10/22/18
121 Reputação
Autoria de 1 guia
Equipe
UC Davis, Team S11-G3, Lore Fall 2018 Membro de UC Davis, Team S11-G3, Lore Fall 2018
UCD-LORE-F18S11G3
Membros da 2
Autoria de 3 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 3
Últimos 30 dias: 8
Duração total: 245
