Ir para o conteúdo principal
HP Pavilion ZD7000 Wi-Fi Card Replacement
O que você precisa
  1. HP Pavilion ZD7000 Wi-Fi Card Replacement, Battery: passo 1, imagem 1 %32
    • Begin by turning the laptop over so that you can see the bottom of the computer.
  2. HP Pavilion ZD7000 Wi-Fi Card Replacement: passo 2, imagem 1 %32
    • Slide the battery release switch to the right while simultaneously lifting up the battery.
  3. HP Pavilion ZD7000 Wi-Fi Card Replacement, Wi-Fi Card: passo 3, imagem 1 %32 HP Pavilion ZD7000 Wi-Fi Card Replacement, Wi-Fi Card: passo 3, imagem 2 %32
    • Unscrew the 2 screws from the plate that cover the Wi-Fi card.
    • Remove the cover.
  4. HP Pavilion ZD7000 Wi-Fi Card Replacement: passo 4, imagem 1 %32 HP Pavilion ZD7000 Wi-Fi Card Replacement: passo 4, imagem 2 %32
    • Disconnect these 2 antenna wires (which eventually connect to the monitor) from the Wi-Fi card.
    • For reassembly, note where the black and white cables connect to the card.
    • Release the Wi-Fi card from the laptop by pressing the metal hinges on either end of it.
    • Gently remove the card from laptop.
Conclusão
3 outras pessoas executaram este guia.
Shantel
Membro desde: 04/20/10
545 Reputação
Autoria de 6 guias
Equipe
Cal Poly, Team 30-37, Garner Spring 2010 Membro de Cal Poly, Team 30-37, Garner Spring 2010
CPSU-GARNER-S10S30G37
Membros da 4
Autoria de 6 guias
2 comentários
Can you upgrade the wifi card?
danoco - Responder
is there a replacement I can buy
Braeden Culp - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 19
Duração total: 5,451
