Esta versão pode conter edições incorretas. Mude para o último instantâneo verificado.
O que você precisa
Este passo não foi traduzido. Ajude a traduzi-lo
Disconnect PC from power source and any other devices.
Turn over computer and remove the rubber feet.
Remove the three 8mm Philips screws with a Philips #0 screwdriver.
Use a pry tool and lift up on the lid.
Remove the two cables connecting the motherboard to the front I/O panel.
From the back I/O panel, pry open the cloth covering.
Remove the 2 black philips screws on the outside of the PC, to the left of the fan.
Put your thumb on the penny-sized hole, and slide the panel upwards.
Remove the panel to reveal the stock blue RAM.
Push both of the white tabs away from the RAM stick to free the RAM.
You can now easily pull the RAM out of the socket, and replace up to two new ones!
Um comentário
Hello srs, i follow the link to the Amazon Ram, and it is So-DIMM, but we need UDIMM for this Wave, it is correct? Wich can we use? Thank you so much, and best regards.
