Ir para o conteúdo principal
HP Pavilion Wave 600-a014 RAM Replacement
O que você precisa
  1. HP Pavilion Wave 600-a014 RAM Replacement, RAM: passo 1, imagem 1 %32
    • Disconnect PC from power source and any other devices.
  2. HP Pavilion Wave 600-a014 RAM Replacement: passo 2, imagem 1 %32 HP Pavilion Wave 600-a014 RAM Replacement: passo 2, imagem 2 %32
    • Turn over computer and remove the rubber feet.
    • Remove the three 8mm Philips screws with a Philips #0 screwdriver.
    • Use a pry tool and lift up on the lid.
  3. HP Pavilion Wave 600-a014 RAM Replacement: passo 3, imagem 1 %32 HP Pavilion Wave 600-a014 RAM Replacement: passo 3, imagem 2 %32
    • Remove the two cables connecting the motherboard to the front I/O panel.
  4. HP Pavilion Wave 600-a014 RAM Replacement: passo 4, imagem 1 %32 HP Pavilion Wave 600-a014 RAM Replacement: passo 4, imagem 2 %32
    • From the back I/O panel, pry open the cloth covering.
  5. HP Pavilion Wave 600-a014 RAM Replacement: passo 5, imagem 1 %32
    • Remove the 2 black philips screws on the outside of the PC, to the left of the fan.
    • There is one on the top and one on the bottom.
  6. HP Pavilion Wave 600-a014 RAM Replacement: passo 6, imagem 1 %32 HP Pavilion Wave 600-a014 RAM Replacement: passo 6, imagem 2 %32 HP Pavilion Wave 600-a014 RAM Replacement: passo 6, imagem 3 %32
    • Put your thumb on the penny-sized hole, and slide the panel upwards.
    • Remove the panel to reveal the stock blue RAM.
  7. HP Pavilion Wave 600-a014 RAM Replacement: passo 7, imagem 1 %32 HP Pavilion Wave 600-a014 RAM Replacement: passo 7, imagem 2 %32 HP Pavilion Wave 600-a014 RAM Replacement: passo 7, imagem 3 %32
    • Push both of the white tabs away from the RAM stick to free the RAM.
  8. HP Pavilion Wave 600-a014 RAM Replacement: passo 8, imagem 1 %32
    • You can now easily pull the RAM out of the socket, and replace up to two new ones!
Conclusão
Arthur Knatt
Membro desde: 09/27/17
149 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team S8-G4, Banghart Fall 2017 Membro de Cal Poly, Team S8-G4, Banghart Fall 2017
CPSU-BANGHART-F17S8G4
Membros da 4
Autoria de 5 guias
Um comentário
Hello srs, i follow the link to the Amazon Ram, and it is So-DIMM, but we need UDIMM for this Wave, it is correct? Wich can we use? Thank you so much, and best regards.
Albert Garcia - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 13
Duração total: 2,983
