Ir para o conteúdo principal
HP Pavilion Wave 600-a014 Mouse and Keyboard Replacement
O que você precisa
  1. HP Pavilion Wave 600-a014 Mouse and Keyboard Replacement, Front IO Board: passo 1, imagem 1 %32 HP Pavilion Wave 600-a014 Mouse and Keyboard Replacement, Front IO Board: passo 1, imagem 2 %32
    • Turn over the computer and remove the rubber feet.
    • Remove the 8mm Philips screws indicated in red circles with a Philips #0 screwdriver.
    • Use a pry tool and lift the lid.
  2. HP Pavilion Wave 600-a014 Mouse and Keyboard Replacement: passo 2, imagem 1 %32 HP Pavilion Wave 600-a014 Mouse and Keyboard Replacement: passo 2, imagem 2 %32
    • Pry open the casing from the back of the IO panel, as shown in the pictures.
  3. HP Pavilion Wave 600-a014 Mouse and Keyboard Replacement: passo 3, imagem 1 %32 HP Pavilion Wave 600-a014 Mouse and Keyboard Replacement: passo 3, imagem 2 %32
    • Finally, remove the two cables circled in red from the front IO panel.
  4. HP Pavilion Wave 600-a014 Mouse and Keyboard Replacement, Mouse and Keyboard adapter: passo 4, imagem 1 %32
    • Locate a blue USB adapter on the left side of the hard disk compartment.
  5. HP Pavilion Wave 600-a014 Mouse and Keyboard Replacement: passo 5, imagem 1 %32 HP Pavilion Wave 600-a014 Mouse and Keyboard Replacement: passo 5, imagem 2 %32
    • Take off the USB with gentle but firm pressure.
    • This is a single USB adapter for both mouse and keyboard, so you must get a wireless mouse and keyboard pair, or you will have to use the extra USB for the other one.
Conclusão
4 outras pessoas executaram este guia.
Kyaw Soe
Membro desde: 09/27/17
321 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team S8-G4, Banghart Fall 2017 Membro de Cal Poly, Team S8-G4, Banghart Fall 2017
CPSU-BANGHART-F17S8G4
Membros da 4
Autoria de 5 guias
3 comentários
Seems like there might be enough room for a usb 2 port hub/splitter (such as Onvian USB Splitter Cable Male to 2 Female Adapter USB) to add an additional usb dongle (such an RF or Insteon USB)? Can you confirm how much room there are?
thomastranrx - Responder
Since it's a year old project, I forgot most of the dimensions, but from my memory, it would be possible since it's located in a little groove that can probably fit a wire or two. (You can see it in step one picture)
Kyaw Soe - Responder
Can i purchase this dongle anywhere? Is there any documentation on how to pair?
will - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 21
Duração total: 2,311
