Ir para o conteúdo principal
Conserte seus objetos
Direito de executar reparos
Peças e ferramentas
Introdução
This guide will walk you through the steps required to obtain access to the hard drive and how to remove and install a replacement drive. Before starting make sure to have a pry tool, and a Philips screw driver handy. Make sure the device is completely powered off and disconnected from any power sources. Additionally remove any devices connected to the computer.
Peças
Nenhum componente especificado.
  1. Disconnect the PC from power source and any other devices.
    • Disconnect the PC from power source and any other devices.
  2. Turn the computer over and remove the rubber feet. Remove the three 8mm Philips screws with a Philips #0 Screwdriver.
    • Turn the computer over and remove the rubber feet.
    • Remove the three 8mm Philips screws with a Philips #0 Screwdriver.
    • Use a pry tool and lift up on the lid.
  3. Telas LCD de reposição iPhone (com ferramentas)
    A opção econômica, coberta por nossa garantia vitalícia.
    Confira os kits
    Reduza os custos de reparo, não a qualidade.
    Confira os kits
  4. Remove the two cables circled in red for the front IO panel. Remove the two cables circled in red for the front IO panel.
    • Remove the two cables circled in red for the front IO panel.
  5. From back IO panel pry open the casing as indicated. From back IO panel pry open the casing as indicated.
    • From back IO panel pry open the casing as indicated.
  6. To remove the hard drive, remove the four 8mm Philips screws using a Philips #0 Screwdriver. Remove Power and SATA cables from on top of the drive. Remove Power and SATA cables from on top of the drive.
    • To remove the hard drive, remove the four 8mm Philips screws using a Philips #0 Screwdriver.
    • Remove Power and SATA cables from on top of the drive.
  7. After screws have been removed grab the Hard Drive and pull it out of the dock.
    • After screws have been removed grab the Hard Drive and pull it out of the dock.
Conclusão
2 outras pessoas concluíram este guia.
Cristian Vanegas
Membro desde: 27-09-2017
249 Reputação
2 Guias de autoria
equipe
Cal Poly, Team S8-G4, Banghart Fall 2017 Membro de Cal Poly, Team S8-G4, Banghart Fall 2017
CPSU-BANGHART-F17S8G4
4 Membros
5 Guias de autoria
Hi there, can you advise whether this was the 128gb SSD or the other 2gb drive?
Joey Franco - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 12
Últimos 30 dias: 31
Duração total: 1,204
