Ir para o conteúdo principal
HP Pavilion Wave 600-a014 Hard Drive Replacement
O que você precisa
  1. HP Pavilion Wave 600-a014 Hard Drive Replacement, Hard Drive: passo 1, imagem 1 %32
    • Disconnect the PC from power source and any other devices.
  2. HP Pavilion Wave 600-a014 Hard Drive Replacement: passo 2, imagem 1 %32 HP Pavilion Wave 600-a014 Hard Drive Replacement: passo 2, imagem 2 %32
    • Turn the computer over and remove the rubber feet.
    • Remove the three 8mm Philips screws with a Philips #0 Screwdriver.
    • Use a pry tool and lift up on the lid.
  3. HP Pavilion Wave 600-a014 Hard Drive Replacement: passo 3, imagem 1 %32 HP Pavilion Wave 600-a014 Hard Drive Replacement: passo 3, imagem 2 %32
    • Remove the two cables circled in red for the front IO panel.
  4. HP Pavilion Wave 600-a014 Hard Drive Replacement: passo 4, imagem 1 %32 HP Pavilion Wave 600-a014 Hard Drive Replacement: passo 4, imagem 2 %32
    • From back IO panel pry open the casing as indicated.
  5. HP Pavilion Wave 600-a014 Hard Drive Replacement: passo 5, imagem 1 %32 HP Pavilion Wave 600-a014 Hard Drive Replacement: passo 5, imagem 2 %32 HP Pavilion Wave 600-a014 Hard Drive Replacement: passo 5, imagem 3 %32
    • To remove the hard drive, remove the four 8mm Philips screws using a Philips #0 Screwdriver.
    • Remove Power and SATA cables from on top of the drive.
  6. HP Pavilion Wave 600-a014 Hard Drive Replacement: passo 6, imagem 1 %32
    • After screws have been removed grab the Hard Drive and pull it out of the dock.
Conclusão
4 outras pessoas executaram este guia.
Cristian Vanegas
Membro desde: 09/27/17
297 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team S8-G4, Banghart Fall 2017 Membro de Cal Poly, Team S8-G4, Banghart Fall 2017
CPSU-BANGHART-F17S8G4
Membros da 4
Autoria de 5 guias
2 comentários
Hi there, can you advise whether this was the 128gb SSD or the other 2gb drive?
Joey Franco - Responder
This model comes with a 3.5" 1TB HDD standard.
Jay Marble -
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 9
Últimos 30 dias: 26
Duração total: 2,350
