Ir para o conteúdo principal
HP Pavilion Touchsmart 11z-e000 Keyboard Replacement
O que você precisa
  1. HP Pavilion Touchsmart 11z-e000 Keyboard Replacement, Battery: passo 1, imagem 1 %32
    • Remove battery by pushing the two tabs and pulling the battery outwards slowly but firmly.
  2. HP Pavilion Touchsmart 11z-e000 Keyboard Replacement, Keyboard: passo 2, imagem 1 %32
    • Use a spudger to slide under the outer plastic cover of the laptop and lift it up and away.
    • Pull off the plastic cover of the laptop.
  3. HP Pavilion Touchsmart 11z-e000 Keyboard Replacement: passo 3, imagem 1 %32
    • Remove all of the silver screws connecting the keyboard plate to the rest of the laptop.
    • This step allows the top plate to be removed from the body of the laptop in the following step.
    12- M2x4 screws to remove. And it helps to remove the screws holding the elbow because it releases the front plate at the top corners.
    Con Fran - Responder
  4. HP Pavilion Touchsmart 11z-e000 Keyboard Replacement: passo 4, imagem 1 %32
    • Use a spudger to lift the keyboard plate off of the base of the computer.
    • Some areas near the hinges may be connected with an adhesive. Take care when removing the plate in these regions.
  5. HP Pavilion Touchsmart 11z-e000 Keyboard Replacement: passo 5, imagem 1 %32
    • Remove the screws connecting the keyboard to the underside of the plate
    • Detach the ribbon wire connecting the keyboard to the hardware.
    • This picture shows the underside of the keyboard after it is removed from the laptop.
  6. HP Pavilion Touchsmart 11z-e000 Keyboard Replacement: passo 6, imagem 1 %32
    • Slowly separate the main part of the keyboard from the metal plate by pressing firmly on the key side of the keyboard and lifting from the back side.
Conclusão
3 outras pessoas executaram este guia.
Robert Hemphill
Membro desde: 01/22/15
269 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team 21-22, Maness Winter 2015 Membro de Cal Poly, Team 21-22, Maness Winter 2015
CPSU-MANESS-W15S21G22
Membros da 4
Autoria de 6 guias
Um comentário
Where can I find a replacement keyboard for the hp pavilion ts 11-e110nr? I've tried a basic search and also Amazon and eBay, but I can't find one anywhere.
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 1
Duração total: 1,656
