Ir para o conteúdo principal
HP Pavilion Touchsmart 11z-e000 Hard Drive Replacement
O que você precisa
  1. HP Pavilion Touchsmart 11z-e000 Hard Drive Replacement, Battery: passo 1, imagem 1 %32
    • Remove battery by pushing the two tabs and pulling the battery outwards slowly but firmly.
  2. HP Pavilion Touchsmart 11z-e000 Hard Drive Replacement, Hard Drive: passo 2, imagem 1 %32
    • Wedge your finger (or tool) in between the outer plastic cover of the laptop and the main part of the laptop.
    • Pry the outer plastic cover off of the laptop.
    • Prying the outer plastic cover off may take a significant amount of force.
  3. HP Pavilion Touchsmart 11z-e000 Hard Drive Replacement: passo 3, imagem 1 %32 HP Pavilion Touchsmart 11z-e000 Hard Drive Replacement: passo 3, imagem 2 %32
    • Unscrew all screws that surround the hard drive with a Philip Head
  4. HP Pavilion Touchsmart 11z-e000 Hard Drive Replacement: passo 4, imagem 1 %32 HP Pavilion Touchsmart 11z-e000 Hard Drive Replacement: passo 4, imagem 2 %32
    • Carefully lift the hard drive up by holding the tag shown here.
  5. HP Pavilion Touchsmart 11z-e000 Hard Drive Replacement: passo 5, imagem 1 %32
    • Remove the final attachment to the hard drive located at the end shown here.
Conclusão
4 outras pessoas executaram este guia.
Robert Hemphill
Membro desde: 01/22/15
269 Reputação
2 Guias de autoria
Equipe
Cal Poly, Team 21-22, Maness Winter 2015 Membro de Cal Poly, Team 21-22, Maness Winter 2015
CPSU-MANESS-W15S21G22
4 Membros
6 Guias de autoria
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 5
Duração total: 2,877
