Ir para o conteúdo principal
HP Pavilion Touchsmart 10-e010nr Battery Replacement
  1. HP Pavilion Touchsmart 10-e010nr Battery Replacement, Battery: passo 1, imagem 1 %32
    • Power off device and place with battery facing up.
    • Ensure that your hands are not wet, even if the laptop is off or dead.
  2. HP Pavilion Touchsmart 10-e010nr Battery Replacement: passo 2, imagem 1 %32 HP Pavilion Touchsmart 10-e010nr Battery Replacement: passo 2, imagem 2 %32
    • Push slider on left-hand side of device into unlocked position. This slider is not spring loaded so it should stay in position afterwards.
  3. HP Pavilion Touchsmart 10-e010nr Battery Replacement: passo 3, imagem 1 %32 HP Pavilion Touchsmart 10-e010nr Battery Replacement: passo 3, imagem 2 %32
    • Push in right-hand slider with your thumb and simultaneously apply slight pressure away from your body.
    • It may be helpful to keep your left thumb on the left slider and push with both thumbs.
  4. HP Pavilion Touchsmart 10-e010nr Battery Replacement: passo 4, imagem 1 %32 HP Pavilion Touchsmart 10-e010nr Battery Replacement: passo 4, imagem 2 %32
    • Battery should easily separate from main device.
Conclusão
Sean
Membro desde: 09/17/18
159 Reputação
Autoria de 1 guia
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 5
Últimos 30 dias: 11
Duração total: 482
