Ir para o conteúdo principal
HP Pavilion TouchSmart 14z-n100 Hard Drive Replacement
O que você precisa
  1. HP Pavilion TouchSmart 14z-n100 Hard Drive Replacement, Hard Drive: passo 1, imagem 1 %32
    • Remove the battery from the device and unplug it.
    • Keep different sized screws separated from each other during disassembly and reassembly.
  2. HP Pavilion TouchSmart 14z-n100 Hard Drive Replacement: passo 2, imagem 1 %32
    • Using a Phillips #0 screwdriver, remove the two screws on the small back cover.
    • Remove the cover.
    • Remove the three screws that have been uncovered.
  3. HP Pavilion TouchSmart 14z-n100 Hard Drive Replacement: passo 3, imagem 1 %32
    • Remove the two rubber screw covers by the rubber feet of the device.
    • Using a Phillips #0 screwdriver, remove the two screws that have been uncovered.
  4. HP Pavilion TouchSmart 14z-n100 Hard Drive Replacement: passo 4, imagem 1 %32
    • Using a Phillips #0 screwdriver, remove the eight screws as directed.
    • Using a Phillips #1 screwdriver, remove the two remaining screws.
  5. HP Pavilion TouchSmart 14z-n100 Hard Drive Replacement: passo 5, imagem 1 %32 HP Pavilion TouchSmart 14z-n100 Hard Drive Replacement: passo 5, imagem 2 %32
    • Using the plastic opening tool, gently pull up the keyboard starting from the bottom left corner, working your way to the bottom right corner.
    • To remove the keyboard, lift up the plastic retaining tab with the opening tool and gently pull out the ribbon wire.
  6. HP Pavilion TouchSmart 14z-n100 Hard Drive Replacement: passo 6, imagem 1 %32
    • Remove the plastic cover of the laptop using the opening tool.
    • The plastic cover is fragile, be cautious during removal.
  7. HP Pavilion TouchSmart 14z-n100 Hard Drive Replacement: passo 7, imagem 1 %32
    • Using the plastic opening tool, pull up the retaining tab and and pull out the ribbon wire
    • This port is fragile, take care in removing and reinserting the ribbon wire.
  8. HP Pavilion TouchSmart 14z-n100 Hard Drive Replacement: passo 8, imagem 1 %32
    • Using a Phillips #0 screwdriver, remove the six screws on the hard drive, then remove it.
    • Be sure to properly dispose or recycle your hard drive.
Conclusão
Justin Hurley
Membro desde: 01/14/19
1 Reputação
Autoria de 1 guia
Equipe
IUPUI, Team S6-G6, Wilson Spring 2019 Membro de IUPUI, Team S6-G6, Wilson Spring 2019
IUPUI-WILSON-S19S6G6
3 Membros
1 Guia de autoria
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 14
Duração total: 298
