Ir para o conteúdo principal
HP Pavilion TouchSmart 14z-n100 Keyboard Replacement
O que você precisa
  1. HP Pavilion TouchSmart 14z-n100  Keyboard Replacement, Keyboard: passo 1, imagem 1 %32
    • Remove these two, 4 mm long number 1 Phillips screws from the device.
  2. HP Pavilion TouchSmart 14z-n100  Keyboard Replacement: passo 2, imagem 1 %32
    • Gently pull the keyboard up with a small plastic opening tool, beginning toward the front right corner. Just pull the keyboard up enough to fit your fingers under.
  3. HP Pavilion TouchSmart 14z-n100  Keyboard Replacement: passo 3, imagem 1 %32
    • Gently pull the keyboard up with your fingers. Do not pull the keyboard too far from the computer.
  4. HP Pavilion TouchSmart 14z-n100  Keyboard Replacement: passo 4, imagem 1 %32 HP Pavilion TouchSmart 14z-n100  Keyboard Replacement: passo 4, imagem 2 %32 HP Pavilion TouchSmart 14z-n100  Keyboard Replacement: passo 4, imagem 3 %32
    • Lift the plastic retaining tab with a small plastic opening tool. The tab will rotate to the side but not remove from the laptop. After this gently pull the wire ribbon to remove it. The old keyboard is now completely removed.
Conclusão
Uma outra pessoa concluiu este guia.
Antonio DiMattia
Membro desde: 08/28/18
133 Reputação
Autoria de 1 guia
Equipe
IUPUI, Team S1-G4, Arle Fall 2018 Membro de IUPUI, Team S1-G4, Arle Fall 2018
IUPUI-ARLE-F18S1G4
Membros da 3
Autoria de 3 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 12
Duração total: 150
