Introdução
This guide demonstrates how to properly replace your HP Pavilion Sleekbook 15 Screen.
O que você precisa
Unplug the device before working on it. Begin by opening the laptop and locating the circular rubber covers at the bottom corners of the screen.
Remove the rubber circles by peeling them away from the laptop revealing two black screws. Save the rubber circles for later when you reassemble the screen.
Use a screwdriver to remove the two 3.6 mm (smaller) screws from the corners of the devices screen.
To reassemble the device, follow the instructions in the reverse order.
5 outras pessoas executaram este guia.
