Ir para o conteúdo principal
Introdução
By using the following tools and the following the steps below, you can simply remove your hard drive from your HP Pavilion Sleekbook and replace it with a new one.
Peças
Nenhum componente especificado.
  1. Open the laptop and locate the keyboard. Identify the borders of the keyboard. Taking plastic opening tools in hand, carefully and gently pry open the outer perimeter of the keyboard. Taking plastic opening tools in hand, carefully and gently pry open the outer perimeter of the keyboard.
    • Open the laptop and locate the keyboard. Identify the borders of the keyboard.
    • Taking plastic opening tools in hand, carefully and gently pry open the outer perimeter of the keyboard.
  2. Once part of the keyboard has popped up, continue to lift the keyboard until it is removed.
    • Once part of the keyboard has popped up, continue to lift the keyboard until it is removed.
  3. Pop out the black frame found underneath the keyboard using the plastic opening tools. Once the frame is popped out continue to lift the frame gently. Once the frame is popped out continue to lift the frame gently.
    • Pop out the black frame found underneath the keyboard using the plastic opening tools.
    • Once the frame is popped out continue to lift the frame gently.
  4. Locate and remove the silver hard drive cover in the bottom right corner. Locate and remove the silver hard drive cover in the bottom right corner. Locate and remove the silver hard drive cover in the bottom right corner.
    • Locate and remove the silver hard drive cover in the bottom right corner.
  5. Detach and remove the hard drive from the black plug located to the right of the hard drive.
    • Detach and remove the hard drive from the black plug located to the right of the hard drive.
Conclusão
12 outras pessoas concluíram este guia.
Rashed
Membro desde: 13/01/2015
670 Reputação
Autoria de 1 guia
Equipe
USF Tampa, Team 3-3, Hickman Winter 2015 Membro de USF Tampa, Team 3-3, Hickman Winter 2015
USFT-HICKMAN-W15S3G3
4 Membros
5 Guias de autoria
6 comentários
Fatto per il modello 15-b131el!!
Simone Milesi - Responder
This technician has left out several crucial steps for this repair several screws on the bottom and several underneath the keyboard before the laptop casing will come apart, common sense for a tech but a how-to should not leave these details out.
dloeper2391 - Responder
These instructions ruined my friends laptops. PLEASE do not post directions like this if you don’t know what you ‘re doing as folks like me will mistakenly assume that you do & attempt this and then damage cables. VERY, VERY careful folks! Cost me $200 for a replacement laptop.
Andre Bajew - Responder
If you do not remove the screws you will crack the keyboard and cover.
HometownComputers - Responder
WIll it support any SSD drive to upgrade from basic HDD?
Gajanan Thirumoolanathan - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 4
Últimos 7 dias: 9
Últimos 30 dias: 47
Duração total: 16,155
