Ir para o conteúdo principal
HP Pavilion Sleekbook 15-b000 Screen Replacement
O que você precisa
  1. HP Pavilion Sleekbook 15-b000 Screen Replacement, Battery: passo 1, imagem 1 %32
    • Unplug laptop from adapter and all other devices.
  2. HP Pavilion Sleekbook 15-b000 Screen Replacement: passo 2, imagem 1 %32
    • Flip the laptop over with battery facing you.
  3. HP Pavilion Sleekbook 15-b000 Screen Replacement: passo 3, imagem 1 %32 HP Pavilion Sleekbook 15-b000 Screen Replacement: passo 3, imagem 2 %32
    • Slide the battery lock on the right side open.
    • Slide the Battery release latch on the left side.
  4. HP Pavilion Sleekbook 15-b000 Screen Replacement: passo 4, imagem 1 %32
    • Pull battery out.
  5. HP Pavilion Sleekbook 15-b000 Screen Replacement, Keyboard: passo 5, imagem 1 %32
    • Remove the two 6.5mm Phillips #1 keyboard screws from bottom of laptop.
  6. HP Pavilion Sleekbook 15-b000 Screen Replacement: passo 6, imagem 1 %32
    • Push screwdriver through screw hole top pop the keyboard.
    • Make sure the screen is open.
  7. HP Pavilion Sleekbook 15-b000 Screen Replacement: passo 7, imagem 1 %32
    • Pry up the keyboard.
    • The keyboard is still attached by it's ribbon.
  8. HP Pavilion Sleekbook 15-b000 Screen Replacement: passo 8, imagem 1 %32
    • Remove keyboard wire by popping latch under blue plastic
  9. HP Pavilion Sleekbook 15-b000 Screen Replacement, Case: passo 9, imagem 1 %32
    • Using the spudger to lift up on the white tabs
    • Pull horizontally on the blue ribbon to disconnect the cables
  10. HP Pavilion Sleekbook 15-b000 Screen Replacement: passo 10, imagem 1 %32
    • Remove the five 5.5mm Phillips #1 screws from the case
  11. HP Pavilion Sleekbook 15-b000 Screen Replacement: passo 11, imagem 1 %32
    • Remove eight 6.5mm Phillips #1 screws from the back cover
  12. HP Pavilion Sleekbook 15-b000 Screen Replacement: passo 12, imagem 1 %32 HP Pavilion Sleekbook 15-b000 Screen Replacement: passo 12, imagem 2 %32 HP Pavilion Sleekbook 15-b000 Screen Replacement: passo 12, imagem 3 %32
    • Starting at a top corner, use the pry tool to split the case.
    • Slowly work around the case, pulling up gently to release the clips.
  13. HP Pavilion Sleekbook 15-b000 Screen Replacement, Screen: passo 13, imagem 1 %32
    • Remove the four 5.5mm Phillips #1 screws attaching the screen.
  14. HP Pavilion Sleekbook 15-b000 Screen Replacement: passo 14, imagem 1 %32
    • Remove the two 3.5mm Phillips #1 screws from the bottom of the screen.
  15. HP Pavilion Sleekbook 15-b000 Screen Replacement: passo 15, imagem 1 %32
    • Remove the screen from it's case.
    • Screen is still connected to it's case by a wire.
  16. HP Pavilion Sleekbook 15-b000 Screen Replacement: passo 16, imagem 1 %32
    • Lay the screen face down on a surface where it ill not scratch
  17. HP Pavilion Sleekbook 15-b000 Screen Replacement: passo 17, imagem 1 %32 HP Pavilion Sleekbook 15-b000 Screen Replacement: passo 17, imagem 2 %32
    • Lift up plastic over latch for the screen.
    • Pull the connector away from the screen to disconnect it.
Conclusão
Sam Barkley
Membro desde: 02/13/18
983 Reputação
Autoria de 8 guias
Equipe
USF Tampa, Team S11-G2, Cheng Spring 2018 Membro de USF Tampa, Team S11-G2, Cheng Spring 2018
USFT-CHENG-S18S11G2
Membros da 4
Autoria de 18 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 7
Duração total: 278
