Introdução
This guide will walk you through the step by step process to remove the mother board from your laptop. You will need to do this if you are having issues with the laptop booting or to remove the WiFi card or RAM.
Ferramentas
Peças
Nenhum componente especificado.
Using the spudger to lift up on the white tabs
Pull horizontally on the blue ribbon to disconnect the cables
Quase terminado!
Conclusão
