Esta versão pode conter edições incorretas. Mude para o último instantâneo verificado.
O que você precisa
Este passo não foi traduzido. Ajude a traduzi-lo
Slide the battery lock on the right side open.
Slide the Battery release latch on the left side.
Remove the two 6.5mm Phillips #1 keyboard screws from bottom of laptop.
Push screwdriver through screw hole top pop the keyboard.
Remove keyboard wire by popping latch under blue plastic
Using the spudger to lift up on the white tabs
Pull horizontally on the blue ribbon to disconnect the cables
Remove the five 5.5mm Phillips #1 screws from the case
Remove eight 6.5mm Phillips #1 screws from the back cover
Starting at a top corner, use the pry tool to split the case.
Slowly work around the case, pulling up gently to release the clips.
Uma outra pessoa concluiu este guia.
