Ir para o conteúdo principal
HP Pavilion Sleekbook 14-b013cl Screen Replacement
O que você precisa
  1. HP Pavilion Sleekbook 14-b013cl Screen Replacement, Battery: passo 1, imagem 1 %32 HP Pavilion Sleekbook 14-b013cl Screen Replacement, Battery: passo 1, imagem 2 %32
    • Flip the computer over and move the battery lock switch to the "unlocked" position (marked by an orange lock icon).
  2. HP Pavilion Sleekbook 14-b013cl Screen Replacement: passo 2, imagem 1 %32 HP Pavilion Sleekbook 14-b013cl Screen Replacement: passo 2, imagem 2 %32
    • Press the switch on the right-hand side of the back of the device towards the center until the gray battery icon is no longer visible. This will eject the battery.
  3. HP Pavilion Sleekbook 14-b013cl Screen Replacement: passo 3, imagem 1 %32 HP Pavilion Sleekbook 14-b013cl Screen Replacement: passo 3, imagem 2 %32
    • Carefully pull the battery away from the device.
  4. HP Pavilion Sleekbook 14-b013cl Screen Replacement, Screen: passo 4, imagem 1 %32 HP Pavilion Sleekbook 14-b013cl Screen Replacement, Screen: passo 4, imagem 2 %32 HP Pavilion Sleekbook 14-b013cl Screen Replacement, Screen: passo 4, imagem 3 %32
    • Using a 1.0 Flathead screwdriver, remove the two stickers covering the screws that hold the screen in place.
    • Use a Phillips #1 screwdriver to remove the two 3.2mm screws that are now visible.
  5. HP Pavilion Sleekbook 14-b013cl Screen Replacement: passo 5, imagem 1 %32 HP Pavilion Sleekbook 14-b013cl Screen Replacement: passo 5, imagem 2 %32 HP Pavilion Sleekbook 14-b013cl Screen Replacement: passo 5, imagem 3 %32
    • Using a plastic opening tool, pry the plastic screen protector off, sliding the tool along the seam. Press the tool in until you hear the plastic tabs clicking as they come undone.
    • Separate the plastic that makes up the hinges for the screen, as they are part of the same screen protector.
    • Use your hands or plastic tool to peel the screen protector away from the adhesive holding it in place.
  6. HP Pavilion Sleekbook 14-b013cl Screen Replacement: passo 6, imagem 1 %32 HP Pavilion Sleekbook 14-b013cl Screen Replacement: passo 6, imagem 2 %32
    • Using a Phillips #1 screwdriver, remove the six 2.8mm screws holding the screen in place.
    • Lift the screen away from the cover until you have access to the connector cable near the bottom of the screen.
  7. HP Pavilion Sleekbook 14-b013cl Screen Replacement: passo 7, imagem 1 %32 HP Pavilion Sleekbook 14-b013cl Screen Replacement: passo 7, imagem 2 %32
    • Peel away any sticker holding the connector in place and simply pull the tab out of the connector parallel with the screen.
    • Remove the screen from the device.
Conclusão
Uma outra pessoa concluiu este guia.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Duração total: 445
