Ir para o conteúdo principal
HP Pavilion Sleekbook 14-b013cl Keyboard Replacement
O que você precisa
  1. HP Pavilion Sleekbook 14-b013cl Keyboard Replacement, Battery: passo 1, imagem 1 %32 HP Pavilion Sleekbook 14-b013cl Keyboard Replacement, Battery: passo 1, imagem 2 %32
    • Flip the computer over and move the battery lock switch to the "unlocked" position (marked by an orange lock icon).
  2. HP Pavilion Sleekbook 14-b013cl Keyboard Replacement: passo 2, imagem 1 %32 HP Pavilion Sleekbook 14-b013cl Keyboard Replacement: passo 2, imagem 2 %32
    • Press the switch on the right-hand side of the back of the device towards the center until the gray battery icon is no longer visible. This will eject the battery.
  3. HP Pavilion Sleekbook 14-b013cl Keyboard Replacement: passo 3, imagem 1 %32 HP Pavilion Sleekbook 14-b013cl Keyboard Replacement: passo 3, imagem 2 %32
    • Carefully pull the battery away from the device.
  4. HP Pavilion Sleekbook 14-b013cl Keyboard Replacement, Keyboard: passo 4, imagem 1 %32
    • Using the Phillips #0 screwdriver, remove the two screws.
  5. HP Pavilion Sleekbook 14-b013cl Keyboard Replacement: passo 5, imagem 1 %32 HP Pavilion Sleekbook 14-b013cl Keyboard Replacement: passo 5, imagem 2 %32 HP Pavilion Sleekbook 14-b013cl Keyboard Replacement: passo 5, imagem 3 %32
    • Use a plastic opening tool to pry up one of the upper counters on the keyboard
    • Run the tool along the upper edge of the keyboard and towards the opposite corner to release the latches.
  6. HP Pavilion Sleekbook 14-b013cl Keyboard Replacement: passo 6, imagem 1 %32 HP Pavilion Sleekbook 14-b013cl Keyboard Replacement: passo 6, imagem 2 %32 HP Pavilion Sleekbook 14-b013cl Keyboard Replacement: passo 6, imagem 3 %32
    • Push the button to release the connector and pull it out and remove the keyboard
Conclusão
Uma outra pessoa concluiu este guia.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 486
