Ir para o conteúdo principal
HP Pavilion N3350 Screen Assembly Replacement
O que você precisa
  1. HP Pavilion N3350 Screen Assembly Replacement, Screen Assembly: passo 1, imagem 1 %32 HP Pavilion N3350 Screen Assembly Replacement, Screen Assembly: passo 1, imagem 2 %32
    • Open your laptop. Beneath the screen, there is a large plastic piece that contains slots for a speaker, the power button, and numerous indicator lights.
    • To remove this, pry it open with a spudger tool gently. It should pop out of place.
  2. HP Pavilion N3350 Screen Assembly Replacement: passo 2, imagem 1 %32 HP Pavilion N3350 Screen Assembly Replacement: passo 2, imagem 2 %32
    • Gently use a spudger tool or your fingers to disconnect the LCD cable from the screen.
    • This is one of three connectors that needs to be undone to disconnect the screen from the laptop.
  3. HP Pavilion N3350 Screen Assembly Replacement: passo 3, imagem 1 %32 HP Pavilion N3350 Screen Assembly Replacement: passo 3, imagem 2 %32 HP Pavilion N3350 Screen Assembly Replacement: passo 3, imagem 3 %32
    • Remove the 1 cm screw with a Phillips #1 screwdriver to allow the screen and top of the laptop to be separated from the keyboard and bottom.
    • Lift the entire top away from the bottom, and set bottom half of the laptop aside.
  4. HP Pavilion N3350 Screen Assembly Replacement: passo 4, imagem 1 %32 HP Pavilion N3350 Screen Assembly Replacement: passo 4, imagem 2 %32 HP Pavilion N3350 Screen Assembly Replacement: passo 4, imagem 3 %32
    • Remove the 6 rubber screw caps with a metal spudger.
    • After removing the 6 rubber screw caps, use a Phillips #1 screwdriver to unscrew the six 6mm screws.
  5. HP Pavilion N3350 Screen Assembly Replacement: passo 5, imagem 1 %32 HP Pavilion N3350 Screen Assembly Replacement: passo 5, imagem 2 %32
    • To separate the plastic cover, use a plastic opening tool to undo each plastic connecting clip between the two.
    • You can find the plastic connecting clips by sliding the plastic opening tool along the seam between the two plastic covers.
    • Remove the top plastic cover once all connections have been released.
  6. HP Pavilion N3350 Screen Assembly Replacement: passo 6, imagem 1 %32 HP Pavilion N3350 Screen Assembly Replacement: passo 6, imagem 2 %32 HP Pavilion N3350 Screen Assembly Replacement: passo 6, imagem 3 %32
    • Disconnect the connectors using a plastic opening tool.
    • Once these two connectors are released, the screen should be electronically freed from the rest of the laptop.
  7. HP Pavilion N3350 Screen Assembly Replacement: passo 7, imagem 1 %32
    • At each corner, there is a 1 centimeter silver screw connecting the screen frame to the laptop. Remove these using a Phillips #1 Screwdriver.
  8. HP Pavilion N3350 Screen Assembly Replacement: passo 8, imagem 1 %32 HP Pavilion N3350 Screen Assembly Replacement: passo 8, imagem 2 %32 HP Pavilion N3350 Screen Assembly Replacement: passo 8, imagem 3 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • There should be thin piece of copper 'tape' holding the LCD cable down. Remove this gently with tweezers.
    • Remove the screen from the device.
Conclusão
Uma outra pessoa concluiu este guia.
Emily Hatstat
Membro desde: 03/19/18
481 Reputação
Autoria de 4 guias
Equipe
UMass Dartmouth, Team S3-G8, Peak Spring 2018 Membro de UMass Dartmouth, Team S3-G8, Peak Spring 2018
UMASSD-PEAK-S18S3G8
Membros da 3
Autoria de 8 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 10
Últimos 30 dias: 19
Duração total: 180
