Ir para o conteúdo principal
HP Pavilion N3350 RAM Replacement
O que você precisa
  1. HP Pavilion N3350 RAM Replacement, RAM: passo 1, imagem 1 %32
    • Locate the RAM on the bottom side of the laptop, the cover is secured by a 6 millimeter screw. Remove this with a Philips #1 screwdriver.
  2. HP Pavilion N3350 RAM Replacement: passo 2, imagem 1 %32
    • Underneath are the RAM boards. They are secured by two plastic clips each. Locate these to continue removal.
  3. HP Pavilion N3350 RAM Replacement: passo 3, imagem 1 %32
    • Place your thumbs on two of the clips securing one board. Push outwards on the clips. This should pop the board up.
  4. HP Pavilion N3350 RAM Replacement: passo 4, imagem 1 %32
    • Repeat on second board. When both are released, they should appear as they do in the picture.
  5. HP Pavilion N3350 RAM Replacement: passo 5, imagem 1 %32
    • The RAM should be easily removed once released from the plastic clips.
Conclusão
Brandon Boisclair
Membro desde: 03/19/18
530 Reputação
Autoria de 3 guias
Equipe
UMass Dartmouth, Team S3-G8, Peak Spring 2018 Membro de UMass Dartmouth, Team S3-G8, Peak Spring 2018
UMASSD-PEAK-S18S3G8
Membros da 3
Autoria de 8 guias
Um comentário
Windows 98 Product Key?
Dudefoxlive - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 10
Duração total: 140
