Ir para o conteúdo principal
HP Pavilion N3350 Peripheral Component Interconnect (PCI) Replacement
O que você precisa
  1. HP Pavilion N3350 Peripheral Component Interconnect (PCI) Replacement, Peripheral Component Interconnect (PCI): passo 1, imagem 1 %32
    • Locate the PCI port, it is next to the CD drive on the right side of the laptop.
  2. HP Pavilion N3350 Peripheral Component Interconnect (PCI) Replacement: passo 2, imagem 1 %32
    • Use a spudger to open the button that disengages the card from the slot.
  3. HP Pavilion N3350 Peripheral Component Interconnect (PCI) Replacement: passo 3, imagem 1 %32 HP Pavilion N3350 Peripheral Component Interconnect (PCI) Replacement: passo 3, imagem 2 %32 HP Pavilion N3350 Peripheral Component Interconnect (PCI) Replacement: passo 3, imagem 3 %32
    • Once popped out, press the button and the inserted PCI should eject and be removed easily.
    • Our laptop contains a NetLINE PC Card that is a primitive Ethernet Network Adapter. This method works for all PCIs inserted to the PCI slot.
Conclusão
Uma outra pessoa concluiu este guia.
Emily Hatstat
Membro desde: 03/19/18
481 Reputação
Autoria de 4 guias
Equipe
UMass Dartmouth, Team S3-G8, Peak Spring 2018 Membro de UMass Dartmouth, Team S3-G8, Peak Spring 2018
UMASSD-PEAK-S18S3G8
Membros da 3
Autoria de 8 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 3
Duração total: 94
