Introdução
If you are using a sound card, video card, or network card in your laptop, they are inserted into the PCI slot. If they are malfunctioning, they need to be replaced or cleaned. Once the respective replacement is purchased, follow the guide to replace.
Peças
Não são necessárias peças.
  1. Locate the PCI port, it is next to the CD drive on the right side of the laptop.
    • Locate the PCI port, it is next to the CD drive on the right side of the laptop.
  2. Use a spudger to open the button that disengages the card from the slot.
    • Use a spudger to open the button that disengages the card from the slot.
    • Once popped out, press the button and the inserted PCI should eject and be removed easily.
    • Our laptop contains a NetLINE PC Card that is a primitive Ethernet Network Adapter. This method works for all PCIs inserted to the PCI slot.
Conclusão
Uma outra pessoa concluiu este guia.
Emily Hatstat
481 reputação
4 Guides authored
Equipe
Visualizar Estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Todo: 18
