Ir para o conteúdo principal
HP Pavilion N3350 Optical Drive Replacement
O que você precisa
  1. HP Pavilion N3350 Optical Drive Replacement, Keyboard: passo 1, imagem 1 %32 HP Pavilion N3350 Optical Drive Replacement, Keyboard: passo 1, imagem 2 %32
    • Open your laptop. Beneath the screen, here is a large plastic piece that contains slots for a speaker, the power button, and numerous indicator lights.
    • To remove this, pry it open with a spudger tool gently. It should pop out of place.
  2. HP Pavilion N3350 Optical Drive Replacement: passo 2, imagem 1 %32 HP Pavilion N3350 Optical Drive Replacement: passo 2, imagem 2 %32
    • Remove the three 6mm screws using a Phillips #1 screwdriver.
    • Once the screws are removed, the keyboard is free from the base of the laptop.
  3. HP Pavilion N3350 Optical Drive Replacement: passo 3, imagem 1 %32 HP Pavilion N3350 Optical Drive Replacement: passo 3, imagem 2 %32
    • Disconnect the green ribbon cable using a plastic opening tool.
  4. HP Pavilion N3350 Optical Drive Replacement, Optical Drives: passo 4, imagem 1 %32 HP Pavilion N3350 Optical Drive Replacement, Optical Drives: passo 4, imagem 2 %32
    • Remove the 6 millimeter screws indicated with a Phillips #1 screwdriver.
    • Remove the top plastic covering from the base of the device.
  5. HP Pavilion N3350 Optical Drive Replacement: passo 5, imagem 1 %32 HP Pavilion N3350 Optical Drive Replacement: passo 5, imagem 2 %32
    • Use a plastic opening tool to disconnect both cable connectors gently.
  6. HP Pavilion N3350 Optical Drive Replacement: passo 6, imagem 1 %32 HP Pavilion N3350 Optical Drive Replacement: passo 6, imagem 2 %32
    • Once these cables are disconnected, the optical drives can be found inside.
    • This particular laptop has a CD/DVD combo drive on the left, and a floppy disc drive on the right.
  7. HP Pavilion N3350 Optical Drive Replacement: passo 7, imagem 1 %32 HP Pavilion N3350 Optical Drive Replacement: passo 7, imagem 2 %32
    • The 1 centimeter screws indicated need to be removed using a Phillips #1 screwdriver to free the CD/DVD combo drive.
    • Once freed, the CD/DVD combo drive should slide out and remove easily.
  8. HP Pavilion N3350 Optical Drive Replacement: passo 8, imagem 1 %32 HP Pavilion N3350 Optical Drive Replacement: passo 8, imagem 2 %32
    • The 1 centimeter screws indicated must be removed with a Phillips #1 screwdriver to free the floppy disc drive.
    • Remove the floppy disc drive from the device.
Conclusão
Uma outra pessoa concluiu este guia.
Lyndon Davis
Membro desde: 03/19/18
124 Reputação
Autoria de 1 guia
Equipe
UMass Dartmouth, Team S3-G8, Peak Spring 2018 Membro de UMass Dartmouth, Team S3-G8, Peak Spring 2018
UMASSD-PEAK-S18S3G8
Membros da 3
Autoria de 8 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 8
Últimos 30 dias: 12
Duração total: 248
