Ir para o conteúdo principal
HP Pavilion G7-2289wm Hard Drive Replacement
O que você precisa
  1. HP Pavilion G7-2289wm Hard Drive Replacement, Battery: passo 1, imagem 1 %32
    • Located on the bottom side of your laptop, slide the battery release latch to the left, towards the center of the laptop.
    • Lift the battery up, and pull towards the center of the laptop to remove it.
  2. HP Pavilion G7-2289wm Hard Drive Replacement, Hard Drive: passo 2, imagem 1 %32
    • Loosen the screw that secures the service cover using a Phillips #0 screwdriver.
    • Pull the edge of the service cover toward you to remove it.
  3. HP Pavilion G7-2289wm Hard Drive Replacement: passo 3, imagem 1 %32
    • Disconnect the hard drive connector cable from the motherboard.
  4. HP Pavilion G7-2289wm Hard Drive Replacement: passo 4, imagem 1 %32
    • Lift the front edge of the hard drive, then pull the hard drive out gently.
Conclusão
Ryson Smith
Membro desde: 03/19/18
636 Reputação
Autoria de 6 guias
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 5
Últimos 30 dias: 8
Duração total: 191
