Introdução
This guide is to provide instruction on how to replace the hard drive in an HP Pavilion G7-2289wm laptop.
O que você precisa
Located on the bottom side of your laptop, slide the battery release latch to the left, towards the center of the laptop.
Lift the battery up, and pull towards the center of the laptop to remove it.
Loosen the screw that secures the service cover using a Phillips #0 screwdriver.
Pull the edge of the service cover toward you to remove it.
