Ir para o conteúdo principal
HP Pavilion G7-2289wm Optical Drive Replacement
O que você precisa
  1. HP Pavilion G7-2289wm Optical Drive Replacement, Battery: passo 1, imagem 1 %32
    • Located on the bottom side of your laptop, slide the battery release latch to the left, towards the center of the laptop.
    • Lift the battery up, and pull towards the center of the laptop to remove it.
  2. HP Pavilion G7-2289wm Optical Drive Replacement, Optical Drive: passo 2, imagem 1 %32
    • Loosen the screw that secures the service cover using a Phillips #0 screwdriver.
    • Lift the edge of the service cover up and forward until it’s at an angle to remove it.
  3. HP Pavilion G7-2289wm Optical Drive Replacement: passo 3, imagem 1 %32 HP Pavilion G7-2289wm Optical Drive Replacement: passo 3, imagem 2 %32
    • Remove the screw that secures the optical drive to the laptop using a Phillips #0 screwdriver.
    • Slide the optical drive out of the laptop.
Conclusão
Ryson Smith
Membro desde: 03/19/18
636 Reputação
Autoria de 6 guias
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 6
Duração total: 279
