Ir para o conteúdo principal
HP Pavilion G7-2235DX Fan Replacement
O que você precisa
  1. HP Pavilion G7-2235DX Fan  Replacement, Fan: passo 1, imagem 1 %32
    • Flip the laptop over and remove six 7.25mm screws.
  2. HP Pavilion G7-2235DX Fan  Replacement: passo 2, imagem 1 %32 HP Pavilion G7-2235DX Fan  Replacement: passo 2, imagem 2 %32
    • Using the plastic opening tool or spudger, separate the keyboard from the frame of the laptop.
    • Gently pull the keyboard away from the laptop, toward you, until it is completely separated from the laptop.
  3. HP Pavilion G7-2235DX Fan  Replacement: passo 3, imagem 1 %32 HP Pavilion G7-2235DX Fan  Replacement: passo 3, imagem 2 %32
    • Remove the four 7.25mm screws located by the red markers.
  4. HP Pavilion G7-2235DX Fan  Replacement: passo 4, imagem 1 %32 HP Pavilion G7-2235DX Fan  Replacement: passo 4, imagem 2 %32
    • Gently lift the panel up, exposing the inside of the laptop.
  5. HP Pavilion G7-2235DX Fan  Replacement: passo 5, imagem 1 %32 HP Pavilion G7-2235DX Fan  Replacement: passo 5, imagem 2 %32
    • The fan is located in the top, left hand corner. Now, it can be gently lifted out using your hands.
Conclusão
Joseph Lampley
Membro desde: 10/11/16
208 Reputação
Autoria de 1 guia
Equipe
USF Tampa, Team 1-7, Leahy Fall 2016 Membro de USF Tampa, Team 1-7, Leahy Fall 2016
USFT-LEAHY-F16S1G7
Membros da 3
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 12
Duração total: 839
