Ir para o conteúdo principal
HP Pavilion G60-630US Hard Drive Replacement
O que você precisa
  1. HP Pavilion G60-630US Hard Drive Replacement, Battery: passo 1, imagem 1 %32 HP Pavilion G60-630US Hard Drive Replacement, Battery: passo 1, imagem 2 %32 HP Pavilion G60-630US Hard Drive Replacement, Battery: passo 1, imagem 3 %32
    • Make sure the laptop is powered off and unplugged first.
    • Turn your laptop over so the bottom is facing up.
    • Locate the battery latch and slide the latch switch all the way to the left.
    • The latch will lock and stay in place.
  2. HP Pavilion G60-630US Hard Drive Replacement: passo 2, imagem 1 %32 HP Pavilion G60-630US Hard Drive Replacement: passo 2, imagem 2 %32 HP Pavilion G60-630US Hard Drive Replacement: passo 2, imagem 3 %32
    • Carefully lift the battery out and away from the laptop.
  3. HP Pavilion G60-630US Hard Drive Replacement, Hard Drive: passo 3, imagem 1 %32
    • Remove the two 5.5 mm JIS#0 screws from the hard drive cover.
    • Remove cover from the back of the laptop.
  4. HP Pavilion G60-630US Hard Drive Replacement: passo 4, imagem 1 %32
    • Remove three 5.5 mm JIS#0 screws.
  5. HP Pavilion G60-630US Hard Drive Replacement: passo 5, imagem 1 %32
    • Gently, slide the whole hard drive to the right with your fingers.
  6. HP Pavilion G60-630US Hard Drive Replacement: passo 6, imagem 1 %32 HP Pavilion G60-630US Hard Drive Replacement: passo 6, imagem 2 %32 HP Pavilion G60-630US Hard Drive Replacement: passo 6, imagem 3 %32
    • Lift up on black tap attached to the hard drive to remove the hard drive.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 2
Últimos 30 dias: 13
Duração total: 740
