Ir para o conteúdo principal
HP Pavilion G60-630US Battery Replacement
  1. HP Pavilion G60-630US Battery Replacement, Battery: passo 1, imagem 1 %32 HP Pavilion G60-630US Battery Replacement, Battery: passo 1, imagem 2 %32 HP Pavilion G60-630US Battery Replacement, Battery: passo 1, imagem 3 %32
    • Make sure the laptop is powered off and unplugged first.
    • Turn your laptop over so the bottom is facing up.
    • Locate the battery latch and slide the latch switch all the way to the left.
    • The latch will lock and stay in place.
  2. HP Pavilion G60-630US Battery Replacement: passo 2, imagem 1 %32 HP Pavilion G60-630US Battery Replacement: passo 2, imagem 2 %32 HP Pavilion G60-630US Battery Replacement: passo 2, imagem 3 %32
    • Carefully lift the battery out and away from the laptop.
Conclusão
To reassemble your device, line up the battery and place it gently on the metal prongs to ensure a stable connection.
[deleted]
Membro desde: 10/02/17
213 Reputação
Autoria de 2 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 12
Duração total: 446
