Ir para o conteúdo principal
HP Pavilion G60-247CL Speaker Replacement
O que você precisa
  1. HP Pavilion G60-247CL Speaker Replacement, Battery: passo 1, imagem 1 %32 HP Pavilion G60-247CL Speaker Replacement, Battery: passo 1, imagem 2 %32 HP Pavilion G60-247CL Speaker Replacement, Battery: passo 1, imagem 3 %32
    • Press down and to the right on the battery lock slide.
    • Once slid over to the right the battery will pop up and out.
  2. HP Pavilion G60-247CL Speaker Replacement, Screen: passo 2, imagem 1 %32
    • Remove the seven Phillips #1 screws from the back side of the laptop.
  3. HP Pavilion G60-247CL Speaker Replacement: passo 3, imagem 1 %32 HP Pavilion G60-247CL Speaker Replacement: passo 3, imagem 2 %32
    • Remove the seven Phillips #0 screws from the battery compartment.
  4. HP Pavilion G60-247CL Speaker Replacement: passo 4, imagem 1 %32 HP Pavilion G60-247CL Speaker Replacement: passo 4, imagem 2 %32 HP Pavilion G60-247CL Speaker Replacement: passo 4, imagem 3 %32
    • Turn the computer around to the front side.
    • Using an opening tool, prop open the keyboard casing.
  5. HP Pavilion G60-247CL Speaker Replacement: passo 5, imagem 1 %32 HP Pavilion G60-247CL Speaker Replacement: passo 5, imagem 2 %32 HP Pavilion G60-247CL Speaker Replacement: passo 5, imagem 3 %32
    • Carefully lift up the keyboard.
    • Gently pull up the connecting wire clip (located in the middle) to completely detach the keyboard.
  6. HP Pavilion G60-247CL Speaker Replacement: passo 6, imagem 1 %32 HP Pavilion G60-247CL Speaker Replacement: passo 6, imagem 2 %32 HP Pavilion G60-247CL Speaker Replacement: passo 6, imagem 3 %32
    • At the top right of the laptop there will be another wire clip holding the keyboard casing.
    • Carefully pull out the wire clip to fully detach the covering.
  7. HP Pavilion G60-247CL Speaker Replacement: passo 7, imagem 1 %32 HP Pavilion G60-247CL Speaker Replacement: passo 7, imagem 2 %32
    Ferramenta utilizada neste passo:
    • At the top right of the laptop remove the black wire from under the metal tabs using the tweezers.
  8. HP Pavilion G60-247CL Speaker Replacement: passo 8, imagem 1 %32 HP Pavilion G60-247CL Speaker Replacement: passo 8, imagem 2 %32
    • Remove the black wire from the top right corner by gently pulling outward.
  9. HP Pavilion G60-247CL Speaker Replacement: passo 9, imagem 1 %32 HP Pavilion G60-247CL Speaker Replacement: passo 9, imagem 2 %32
    • At the top left of the computer remove the black clip using the opening tool.
    • Push the opening tool to the right to pop out the clip.
  10. HP Pavilion G60-247CL Speaker Replacement: passo 10, imagem 1 %32 HP Pavilion G60-247CL Speaker Replacement: passo 10, imagem 2 %32 HP Pavilion G60-247CL Speaker Replacement: passo 10, imagem 3 %32
    • Locate at the bottom left of the computer a white clip.
    • Using an opening tool, prop out the white clip.
  11. HP Pavilion G60-247CL Speaker Replacement: passo 11, imagem 1 %32 HP Pavilion G60-247CL Speaker Replacement: passo 11, imagem 2 %32
    • On the left side of the computer locate the black wire with the clear clip.
    • Gently pull the wire to the right to detach it.
  12. HP Pavilion G60-247CL Speaker Replacement: passo 12, imagem 1 %32 HP Pavilion G60-247CL Speaker Replacement: passo 12, imagem 2 %32 HP Pavilion G60-247CL Speaker Replacement: passo 12, imagem 3 %32
    • At the top corners of the computer, unscrew the three Phillips #0 screws.
    • Lift up the top half of the computer carefully.
  13. HP Pavilion G60-247CL Speaker Replacement: passo 13, imagem 1 %32 HP Pavilion G60-247CL Speaker Replacement: passo 13, imagem 2 %32 HP Pavilion G60-247CL Speaker Replacement: passo 13, imagem 3 %32
    • Locate the two screws at the bottom corners of the screen.
    • Using the tweezers remove the rubber black covering over the screw.
    • Remove the two Phillips #0 screws.
  14. HP Pavilion G60-247CL Speaker Replacement: passo 14, imagem 1 %32 HP Pavilion G60-247CL Speaker Replacement: passo 14, imagem 2 %32 HP Pavilion G60-247CL Speaker Replacement: passo 14, imagem 3 %32
    • Using the opening tool, prop off the screen covering.
    • Remove the covering to expose the screen completely.
  15. HP Pavilion G60-247CL Speaker Replacement: passo 15, imagem 1 %32 HP Pavilion G60-247CL Speaker Replacement: passo 15, imagem 2 %32 HP Pavilion G60-247CL Speaker Replacement: passo 15, imagem 3 %32
    • Remove the bottom two screen bearings.
    • Using a Phillips 1 screwdriver, remove the two screws on each side.
  16. HP Pavilion G60-247CL Speaker Replacement: passo 16, imagem 1 %32 HP Pavilion G60-247CL Speaker Replacement: passo 16, imagem 2 %32
    • Using the tweezers remove the red and white wire from the bottom of the screen.
  17. HP Pavilion G60-247CL Speaker Replacement: passo 17, imagem 1 %32 HP Pavilion G60-247CL Speaker Replacement: passo 17, imagem 2 %32
    • Prop the screen up slightly.
    • Using the tweezers unclip the white wire.
  18. HP Pavilion G60-247CL Speaker Replacement: passo 18, imagem 1 %32 HP Pavilion G60-247CL Speaker Replacement: passo 18, imagem 2 %32
    • While the screen is still propped open, remove the black wire from the bottom middle of the screen by pulling gently.
  19. HP Pavilion G60-247CL Speaker Replacement: passo 19, imagem 1 %32
    • Remove the screen from the outer casing carefully.
  20. HP Pavilion G60-247CL Speaker Replacement, RAM: passo 20, imagem 1 %32
    • Locate RAM access door on the bottom side of the laptop.
  21. HP Pavilion G60-247CL Speaker Replacement: passo 21, imagem 1 %32 HP Pavilion G60-247CL Speaker Replacement: passo 21, imagem 2 %32 HP Pavilion G60-247CL Speaker Replacement: passo 21, imagem 3 %32
    • Remove the two screws holding down the RAM access door with a Phillips #1 screwdriver.
  22. HP Pavilion G60-247CL Speaker Replacement: passo 22, imagem 1 %32 HP Pavilion G60-247CL Speaker Replacement: passo 22, imagem 2 %32
    • Lift up on the RAM cover and remove it to reveal RAM sticks.
  23. HP Pavilion G60-247CL Speaker Replacement: passo 23, imagem 1 %32 HP Pavilion G60-247CL Speaker Replacement: passo 23, imagem 2 %32
    • Gently pull apart the two metal tabs located on both sides of the stick of RAM.
  24. HP Pavilion G60-247CL Speaker Replacement: passo 24, imagem 1 %32
    • Gently lift the RAM stick up and out of its seat.
  25. HP Pavilion G60-247CL Speaker Replacement: passo 25, imagem 1 %32
    • Repeat the previous two steps for the remaining stick of RAM.
  26. HP Pavilion G60-247CL Speaker Replacement, Speakers: passo 26, imagem 1 %32 HP Pavilion G60-247CL Speaker Replacement, Speakers: passo 26, imagem 2 %32
    • Remove the battery and RAM.
    • Locate the hard drive access panel.
    • Remove the two 1.2mm Phillips #1 screws on the hard drive access panel.
  27. HP Pavilion G60-247CL Speaker Replacement: passo 27, imagem 1 %32 HP Pavilion G60-247CL Speaker Replacement: passo 27, imagem 2 %32
    • After the screws are removed, slide the hard drive panel to the right to remove it.
  28. HP Pavilion G60-247CL Speaker Replacement: passo 28, imagem 1 %32 HP Pavilion G60-247CL Speaker Replacement: passo 28, imagem 2 %32
    • Identify the 3 screws holding the hard drive's cover in place.
    • Use a Phillips #0 screwdriver to remove the 3 screws and reveal the hard drive.
    • This particular laptop does not contain a hard drive-- yours will.
  29. HP Pavilion G60-247CL Speaker Replacement: passo 29, imagem 1 %32 HP Pavilion G60-247CL Speaker Replacement: passo 29, imagem 2 %32
    • Locate the storage battery, next to the hard drive.
    • Gently pop out the storage battery with your fingers.
  30. HP Pavilion G60-247CL Speaker Replacement: passo 30, imagem 1 %32 HP Pavilion G60-247CL Speaker Replacement: passo 30, imagem 2 %32
    • Locate the Wi-Fi card cover panel, to the left of the RAM.
    • Use a Phillips #1 screwdriver to remove the screw from the Wi-Fi card cover panel.
  31. HP Pavilion G60-247CL Speaker Replacement: passo 31, imagem 1 %32 HP Pavilion G60-247CL Speaker Replacement: passo 31, imagem 2 %32
    • Lift up on the screw side to remove the panel.
  32. HP Pavilion G60-247CL Speaker Replacement: passo 32, imagem 1 %32 HP Pavilion G60-247CL Speaker Replacement: passo 32, imagem 2 %32
    • Remove two 1.2 mm Phillips #01 screws.
    • When the screws are removed, the Wi-Fi card will pop up.
  33. HP Pavilion G60-247CL Speaker Replacement: passo 33, imagem 1 %32 HP Pavilion G60-247CL Speaker Replacement: passo 33, imagem 2 %32
    • Remove the Wi-Fi card by pulling it to the left of the laptop.
  34. HP Pavilion G60-247CL Speaker Replacement: passo 34, imagem 1 %32
    • Flip the laptop over to the top view.
    • Remove five 1.2 mm Phillips #00 screws.
  35. HP Pavilion G60-247CL Speaker Replacement: passo 35, imagem 1 %32 HP Pavilion G60-247CL Speaker Replacement: passo 35, imagem 2 %32
    • Use a spudger to unclip the casing around all the corners and edges of the laptop.
  36. HP Pavilion G60-247CL Speaker Replacement: passo 36, imagem 1 %32 HP Pavilion G60-247CL Speaker Replacement: passo 36, imagem 2 %32
    • Lift up and remove the casing to reveal the speakers.
  37. HP Pavilion G60-247CL Speaker Replacement: passo 37, imagem 1 %32
    • Remove the highlighted 1.2 mm Phillips #00 screw from the right speaker.
  38. HP Pavilion G60-247CL Speaker Replacement: passo 38, imagem 1 %32 HP Pavilion G60-247CL Speaker Replacement: passo 38, imagem 2 %32
    • Using a spudger, remove the highlighted white wire.
  39. HP Pavilion G60-247CL Speaker Replacement: passo 39, imagem 1 %32 HP Pavilion G60-247CL Speaker Replacement: passo 39, imagem 2 %32 HP Pavilion G60-247CL Speaker Replacement: passo 39, imagem 3 %32
    • Using a spudger, remove both highlighted wires from the motherboard.
  40. HP Pavilion G60-247CL Speaker Replacement: passo 40, imagem 1 %32 HP Pavilion G60-247CL Speaker Replacement: passo 40, imagem 2 %32 HP Pavilion G60-247CL Speaker Replacement: passo 40, imagem 3 %32
    • Lift each speaker up and out from the base.
Conclusão
Zachary Herrera
Membro desde: 03/20/18
485 Reputação
Autoria de 2 guias
Equipe
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 15
Ao todo: 347
