Ir para o conteúdo principal
HP Pavilion G60-247CL Screen Replacement
O que você precisa
  1. HP Pavilion G60-247CL Screen Replacement, Battery: passo 1, imagem 1 %32 HP Pavilion G60-247CL Screen Replacement, Battery: passo 1, imagem 2 %32 HP Pavilion G60-247CL Screen Replacement, Battery: passo 1, imagem 3 %32
    • Press down and to the right on the battery lock slide.
    • Once slid over to the right the battery will pop up and out.
  2. HP Pavilion G60-247CL Screen Replacement, Screen: passo 2, imagem 1 %32
    • Remove the seven Phillips #1 screws from the back side of the laptop.
  3. HP Pavilion G60-247CL Screen Replacement: passo 3, imagem 1 %32 HP Pavilion G60-247CL Screen Replacement: passo 3, imagem 2 %32
    • Remove the seven Phillips #0 screws from the battery compartment.
  4. HP Pavilion G60-247CL Screen Replacement: passo 4, imagem 1 %32 HP Pavilion G60-247CL Screen Replacement: passo 4, imagem 2 %32 HP Pavilion G60-247CL Screen Replacement: passo 4, imagem 3 %32
    • Turn the computer around to the front side.
    • Using an opening tool (Spudger), prop open the keyboard casing.
  5. HP Pavilion G60-247CL Screen Replacement: passo 5, imagem 1 %32 HP Pavilion G60-247CL Screen Replacement: passo 5, imagem 2 %32 HP Pavilion G60-247CL Screen Replacement: passo 5, imagem 3 %32
    • Carefully lift up the keyboard.
    • Gently pull up the connecting wire clip (located in the middle) to completely detach the keyboard.
  6. HP Pavilion G60-247CL Screen Replacement: passo 6, imagem 1 %32 HP Pavilion G60-247CL Screen Replacement: passo 6, imagem 2 %32 HP Pavilion G60-247CL Screen Replacement: passo 6, imagem 3 %32
    • At the top right of the laptop there will be another wire clip holding the keyboard casing.
    • Carefully pull out the wire clip to fully detach the covering.
  7. HP Pavilion G60-247CL Screen Replacement: passo 7, imagem 1 %32 HP Pavilion G60-247CL Screen Replacement: passo 7, imagem 2 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • At the top right of the laptop remove the black wire from under the metal tabs using the tweezers.
  8. HP Pavilion G60-247CL Screen Replacement: passo 8, imagem 1 %32 HP Pavilion G60-247CL Screen Replacement: passo 8, imagem 2 %32
    • Remove the black wire from the top right corner by gently pulling outward.
  9. HP Pavilion G60-247CL Screen Replacement: passo 9, imagem 1 %32 HP Pavilion G60-247CL Screen Replacement: passo 9, imagem 2 %32
    • At the top left of the computer remove the black clip using the opening tool.
    • Push the opening tool to the right to pop out the clip.
  10. HP Pavilion G60-247CL Screen Replacement: passo 10, imagem 1 %32 HP Pavilion G60-247CL Screen Replacement: passo 10, imagem 2 %32 HP Pavilion G60-247CL Screen Replacement: passo 10, imagem 3 %32
    • Locate at the bottom left of the computer a white clip.
    • Using an opening tool, prop out the white clip.
  11. HP Pavilion G60-247CL Screen Replacement: passo 11, imagem 1 %32 HP Pavilion G60-247CL Screen Replacement: passo 11, imagem 2 %32
    • On the left side of the computer locate the black wire with the clear clip.
    • Gently pull the wire to the right to detach it.
  12. HP Pavilion G60-247CL Screen Replacement: passo 12, imagem 1 %32 HP Pavilion G60-247CL Screen Replacement: passo 12, imagem 2 %32 HP Pavilion G60-247CL Screen Replacement: passo 12, imagem 3 %32
    • At the top corners of the computer, unscrew the three Phillips #0 screws.
    • Lift up the top half of the computer carefully.
  13. HP Pavilion G60-247CL Screen Replacement: passo 13, imagem 1 %32 HP Pavilion G60-247CL Screen Replacement: passo 13, imagem 2 %32 HP Pavilion G60-247CL Screen Replacement: passo 13, imagem 3 %32
    • Locate the two screws at the bottom corners of the screen.
    • Using the tweezers remove the rubber black covering over the screw.
    • Remove the two Phillips #0 screws.
  14. HP Pavilion G60-247CL Screen Replacement: passo 14, imagem 1 %32 HP Pavilion G60-247CL Screen Replacement: passo 14, imagem 2 %32 HP Pavilion G60-247CL Screen Replacement: passo 14, imagem 3 %32
    • Using the opening tool, prop off the screen covering.
    • Remove the covering to expose the screen completely.
  15. HP Pavilion G60-247CL Screen Replacement: passo 15, imagem 1 %32 HP Pavilion G60-247CL Screen Replacement: passo 15, imagem 2 %32 HP Pavilion G60-247CL Screen Replacement: passo 15, imagem 3 %32
    • Remove the bottom two screen bearings.
    • Using a Phillips 1 screwdriver, remove the two screws on each side.
  16. HP Pavilion G60-247CL Screen Replacement: passo 16, imagem 1 %32 HP Pavilion G60-247CL Screen Replacement: passo 16, imagem 2 %32
    • Using the tweezers remove the red and white wire from the bottom of the screen.
  17. HP Pavilion G60-247CL Screen Replacement: passo 17, imagem 1 %32 HP Pavilion G60-247CL Screen Replacement: passo 17, imagem 2 %32
    • Prop the screen up slightly .
    • Using the tweezers unclip the white wire.
  18. HP Pavilion G60-247CL Screen Replacement: passo 18, imagem 1 %32 HP Pavilion G60-247CL Screen Replacement: passo 18, imagem 2 %32
    • While the screen is still propped open remove the black wire from the bottom middle of the screen by pulling gently.
  19. HP Pavilion G60-247CL Screen Replacement: passo 19, imagem 1 %32
    • Remove the screen from the outer casing carefully.
Conclusão
Haley Matthews
Membro desde: 03/12/18
517 Reputação
Autoria de 3 guias
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 4
Últimos 30 dias: 15
Duração total: 301
