Ir para o conteúdo principal
HP Pavilion G60-247CL RAM Replacement
O que você precisa
  1. HP Pavilion G60-247CL RAM Replacement, Battery: passo 1, imagem 1 %32 HP Pavilion G60-247CL RAM Replacement, Battery: passo 1, imagem 2 %32 HP Pavilion G60-247CL RAM Replacement, Battery: passo 1, imagem 3 %32
    • Press down and to the right on the battery lock slide.
    • Once slid over to the right the battery will pop up and out.
  2. HP Pavilion G60-247CL RAM Replacement, RAM: passo 2, imagem 1 %32
    • Locate RAM access door on the bottom side of the laptop.
  3. HP Pavilion G60-247CL RAM Replacement: passo 3, imagem 1 %32 HP Pavilion G60-247CL RAM Replacement: passo 3, imagem 2 %32 HP Pavilion G60-247CL RAM Replacement: passo 3, imagem 3 %32
    • Remove the two screws holding down the RAM access door with a Phillips #1 screwdriver.
  4. HP Pavilion G60-247CL RAM Replacement: passo 4, imagem 1 %32 HP Pavilion G60-247CL RAM Replacement: passo 4, imagem 2 %32
    • Lift up on the RAM cover and remove it to reveal RAM sticks.
  5. HP Pavilion G60-247CL RAM Replacement: passo 5, imagem 1 %32 HP Pavilion G60-247CL RAM Replacement: passo 5, imagem 2 %32
    • Gently pull apart the two metal tabs located on both sides of the stick of RAM.
  6. HP Pavilion G60-247CL RAM Replacement: passo 6, imagem 1 %32
    • Gently lift the RAM stick up and out of its seat.
  7. HP Pavilion G60-247CL RAM Replacement: passo 7, imagem 1 %32
    • Repeat the previous two steps for the remaining stick of RAM.
Conclusão
Zachary Herrera
Membro desde: 03/20/18
485 Reputação
Autoria de 2 guias
Equipe
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 12
Ao todo: 170
