Ir para o conteúdo principal
HP Pavilion G60-235DX Ram Replacement
O que você precisa
  1. HP Pavilion G60-235DX Ram Replacement, Ram: passo 1, imagem 1 %32
    • Lay the computer so that the backside is facing you and locate the screw in the picture.
  2. HP Pavilion G60-235DX Ram Replacement: passo 2, imagem 1 %32
    • Remove the screws.
  3. HP Pavilion G60-235DX Ram Replacement: passo 3, imagem 1 %32
    • Remove the cover that was held in by the screws that you just removed.
  4. HP Pavilion G60-235DX Ram Replacement: passo 4, imagem 1 %32
    • Push this slide over in order to remove the battery. This is safe when working with your computers memory.
  5. HP Pavilion G60-235DX Ram Replacement: passo 5, imagem 1 %32
    • Remove each one of the rams so that the computer looks like this. You can do so be squeezing tabs on each side of the ram.
Conclusão
James de Fremery
Membro desde: 01/26/17
201 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team 10-5, Banghart Winter 2017 Membro de Cal Poly, Team 10-5, Banghart Winter 2017
CPSU-BANGHART-W17S10G5
Membros da 3
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 9
Duração total: 183
