Ir para o conteúdo principal
HP Pavilion G60-235DX Keyboard Replacement
O que você precisa
  1. HP Pavilion G60-235DX Keyboard  Replacement, Keyboard: passo 1, imagem 1 %32 HP Pavilion G60-235DX Keyboard  Replacement, Keyboard: passo 1, imagem 2 %32
    • Please turn the power of your device off. If not, it may cause a damage to the computer's hard drive and the person.
    • Slide the lock to remove the battery
    • After removing the battery, you can find 8 screws where battery were placed. Unscrew those 8 screws.
  2. HP Pavilion G60-235DX Keyboard  Replacement: passo 2, imagem 1 %32 HP Pavilion G60-235DX Keyboard  Replacement: passo 2, imagem 2 %32 HP Pavilion G60-235DX Keyboard  Replacement: passo 2, imagem 3 %32
    • Do not force if the frame is not coming out. It may break the clip of the frame.
    • After the screws from battery house are removed, open the laptop to remove the keyboard frame.
    • Approach the frame on the side by using the prying tool. Carefully remove the clip. Watch out not to break the clip.
    • Then use the prying tool to carefully remove the frame from the top. Be careful not to break the clip.
    • Then, press the button located top of the touch pad to completely remove the frame from the bottom of the frame.
  3. HP Pavilion G60-235DX Keyboard  Replacement: passo 3, imagem 1 %32
    • When the frame is removed, keyboard will be free to be removed. There is cable ribbon to be removed. Gently pull out the ribbon from where it is plugged.
    • The keyboard is now detached from the computer.
Conclusão
Gilbert Han
Membro desde: 01/24/17
241 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team 10-5, Banghart Winter 2017 Membro de Cal Poly, Team 10-5, Banghart Winter 2017
CPSU-BANGHART-W17S10G5
Membros da 3
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 10
Duração total: 481
