Introdução
This guide will help with the replacement of the laptop fan. Steps 8-11 are included for the disassembly of the HP Pavilion G60-235DX, and are not necessary for the replacement of the laptop fan.
O que você precisa
Slide the lock to remove the battery
After removing the battery, you can find 8 screws where battery were placed. Unscrew those 8 screws.
After the screws from battery house are removed, open the laptop to remove the keyboard frame.
Approach the frame on the side by using the prying tool. Carefully remove the clip. Watch out not to break the clip.
Then use the prying tool to carefully remove the frame from the top. Be careful not to break the clip.
Then, press the button located top of the touch pad to completely remove the frame from the bottom of the frame.
Unplug two wires by gently pulling it out.
Then remove two wires from the clip that was holding the wire in place.
Lay the computer so that the backside is facing you and locate the screw in the picture.
Remove the plate on the upper left side of the back plate, shown here.
You will need to use a screwdriver to remove the 5 mm screws holding this plate down.
