Introdução
If your HP Pavilion G6-1d16dx won't close/open correctly, you could have a faulty screen hinge. This guide walks users through the process of accessing/replacing the screen hinges so that their computer will open and close correctly.
Before following this guide, check to see if there is anything external that may be inhibiting your screen from closing correctly, or if there is any sort of dust or debris buildup in the hinges of your computer; any buildup can typically be removed with an air duster.
Before beginning, be sure that your computer is fully turned off and unplugged from any power source.
O que você precisa
Flip the computer so that the bottom side is facing up, and locate the battery above the screen hinges.
Unscrew the two silver screws holding the protective cover in place until they make a clicking noise.
Um comentário
Not so good a manual. See my remarks.
This laptop is of extremely poor building quality. Disaster lures in every badly made detail.
