Ir para o conteúdo principal
HP Pavilion DV9700 RAM Replacement
O que você precisa
  1. HP Pavilion DV9700 RAM Replacement, RAM: passo 1, imagem 1 %32 HP Pavilion DV9700 RAM Replacement, RAM: passo 1, imagem 2 %32
    • Turn the device over so that the bottom is facing upward.
    • Locate the three panels near the bottom half of the device.
    • The middle-most panel is the one we will be focusing on.
    • Using a Philips #0 screwdriver, unscrew the two 4mm screws that hold this panel in place.
  2. HP Pavilion DV9700 RAM Replacement: passo 2, imagem 1 %32 HP Pavilion DV9700 RAM Replacement: passo 2, imagem 2 %32
    • Pull the bottom of the panel upward.
    • Then pull the panel toward yourself to remove.
  3. HP Pavilion DV9700 RAM Replacement: passo 3, imagem 1 %32 HP Pavilion DV9700 RAM Replacement: passo 3, imagem 2 %32 HP Pavilion DV9700 RAM Replacement: passo 3, imagem 3 %32
    • Look toward the top half of the exposed compartment.
    • Each ram stick will have two silver clips on the left and right side.
    • Push these clips outward at the same time to release the ram stick.
  4. HP Pavilion DV9700 RAM Replacement: passo 4, imagem 1 %32 HP Pavilion DV9700 RAM Replacement: passo 4, imagem 2 %32 HP Pavilion DV9700 RAM Replacement: passo 4, imagem 3 %32
    • The ram stick will be held at a 45 degree angle. Pull the stick upward to release it from the slot.
    • Each ram stick will have a notch near the bottom, make sure to keep note of which side this notch is on.
    • Make sure to place the ram away from any static surfaces (carpet, fabric, etc.)
Conclusão
Max Shangraw
Membro desde: 03/19/18
507 Reputação
Autoria de 4 guias
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 2
Últimos 30 dias: 17
Duração total: 771
