Introdução
If your laptop is struggling to run multiple tabs, or if you are looking to upgrade your ram, consult this repair guide. To complete this repair guide all you will need is a Philip's head screwdriver.
O que você precisa
Turn the device over so that the bottom is facing upward.
Locate the three panels near the bottom half of the device.
The middle-most panel is the one we will be focusing on.
Using a Philips #0 screwdriver, unscrew the two 4mm screws that hold this panel in place.
