Ir para o conteúdo principal
HP Pavilion DV9700 Optical Drive Replacement
O que você precisa
  1. HP Pavilion DV9700 Optical Drive  Replacement, Optical Drive: passo 1, imagem 1 %32 HP Pavilion DV9700 Optical Drive  Replacement, Optical Drive: passo 1, imagem 2 %32 HP Pavilion DV9700 Optical Drive  Replacement, Optical Drive: passo 1, imagem 3 %32
    • Turn the device over so that the bottom is facing upward.
    • Find the screw with an imprint of a disk underneath it. It is located near the center of the device.
    • Remove this 6mm screw with a Philips #0 screwdriver.
    • This screw is very small, make sure to have an organized place to put it.
  2. HP Pavilion DV9700 Optical Drive  Replacement: passo 2, imagem 1 %32 HP Pavilion DV9700 Optical Drive  Replacement: passo 2, imagem 2 %32 HP Pavilion DV9700 Optical Drive  Replacement: passo 2, imagem 3 %32
    • The optical drive is located toward the left side of the device.
    • Using a spudger, pry the optical drive away from the casing.
    • Pull the rest of the optical drive out with your hand.
Conclusão
Uma outra pessoa concluiu este guia.
Max Shangraw
Membro desde: 03/19/18
507 Reputação
Autoria de 4 guias
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 3
Últimos 30 dias: 6
Duração total: 331
