Introdução
After years of device usage, parts start to malfunction or wear out. If you are experiencing problems with your digital media control panel consult this repair guide to restore your device to working order. To start this guide all you will need is a screwdriver and a spudger tool.
O que você precisa
First turn the device so that the back is facing upward.
There is a tab located near the top left portion of the device.
Push the tab and pull the battery upward to remove the battery from the device.
