Ir para o conteúdo principal
HP Pavilion DV5T-1000 Hard Drive Replacement
O que você precisa
    • Make sure the laptop is turned off, and the power cable is removed.
    • Leaving the laptop turned on can cause damage to the hardware and any stored data.
  1. HP Pavilion DV5T-1000 Hard Drive Replacement: passo 2, imagem 1 %32
    • Turn the laptop over to access the backside of the computer.
    • Identify and confirm that the laptop is an HP Pavilion DV5T-1000.
  2. HP Pavilion DV5T-1000 Hard Drive Replacement: passo 3, imagem 1 %32 HP Pavilion DV5T-1000 Hard Drive Replacement: passo 3, imagem 2 %32
    • Slide the battery lock to the left, it's located just below the battery compartment.
    • Pull the battery up and out, to remove it from the battery compartment.
    • To prevent hardware damage, remove the battery before working on the laptop.
  3. HP Pavilion DV5T-1000 Hard Drive Replacement: passo 4, imagem 1 %32
    • Identify the hard drive compartment, located at the top left-hand frame of the laptop.
  4. HP Pavilion DV5T-1000 Hard Drive Replacement: passo 5, imagem 1 %32
    • In order to remove the hard drive compartment cover, first remove the two screws located on the panel, using a size 0 Phillips head screwdriver.
  5. HP Pavilion DV5T-1000 Hard Drive Replacement: passo 6, imagem 1 %32
    • Expose the hard drive by lifting the drive cover.
  6. HP Pavilion DV5T-1000 Hard Drive Replacement: passo 7, imagem 1 %32
    • In order to loosen the hard drive from the motherboard, tug gently on the black tabs located at both ends of the hard drive.
    • Be cautious when handling the cable that connects the hard drive to the computer's motherboard.
  7. HP Pavilion DV5T-1000 Hard Drive Replacement: passo 8, imagem 1 %32 HP Pavilion DV5T-1000 Hard Drive Replacement: passo 8, imagem 2 %32
    • Firmly hold both the black plug, and the hard drive itself to separate the drive from the cable.
  8. HP Pavilion DV5T-1000 Hard Drive Replacement: passo 9, imagem 1 %32 HP Pavilion DV5T-1000 Hard Drive Replacement: passo 9, imagem 2 %32
    • Remove the 4 screws using a size 0 Phillips head screwdriver.
    • Remove the metal from the perimeter of the hard drive.
Conclusão
4 outras pessoas executaram este guia.
Josh Taimanglo
Membro desde: 09/21/15
147 Reputação
Autoria de 1 guia
Equipe
Um comentário
Help after replacing hard drive installation of windows
Bettyjean Serrano - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 8
Últimos 30 dias: 44
Duração total: 1,876
