Ir para o conteúdo principal
HP Pavilion DV3 RAM Replacement
O que você precisa
  1. HP Pavilion DV3 RAM Replacement, Battery: passo 1, imagem 1 %32
    • Step 1 – Battery: Locate the battery release slider on the bottom of the laptop and move it in the direction of the arrow to the unlock position.
    • The yellow highlighted edge of the battery should pop up slightly when the switch is moved
  2. HP Pavilion DV3 RAM Replacement: passo 2, imagem 1 %32 HP Pavilion DV3 RAM Replacement: passo 2, imagem 2 %32
    • Step 2: Using the edge of the battery that has popped up, lift the battery out of the computer.
  3. HP Pavilion DV3 RAM Replacement, RAM: passo 3, imagem 1 %32 HP Pavilion DV3 RAM Replacement, RAM: passo 3, imagem 2 %32 HP Pavilion DV3 RAM Replacement, RAM: passo 3, imagem 3 %32
    • Remove the two 3.5 mm diameter head and 7 mm long screws using the Philips PH1 screwdriver.
    • Both screws will remain attached to the cover.
    • Set the cover with attached screws to the side.
    • The RAM will now be exposed
  4. HP Pavilion DV3 RAM Replacement: passo 4, imagem 1 %32 HP Pavilion DV3 RAM Replacement: passo 4, imagem 2 %32 HP Pavilion DV3 RAM Replacement: passo 4, imagem 3 %32
    • Find the two clips located on each side of the RAM.
    • Using both hands, simultaneously grab each clip and open them away from the RAM stick.
    • The RAM will pop up.
  5. HP Pavilion DV3 RAM Replacement: passo 5, imagem 1 %32 HP Pavilion DV3 RAM Replacement: passo 5, imagem 2 %32
    • Using one hand, pull the RAM up and to the left to remove it.
  6. HP Pavilion DV3 RAM Replacement: passo 6, imagem 1 %32
    • If there is a second RAM module present (as shown), repeat steps 2 and 3 to remove it.
Conclusão
Brandon Baldovin
Membro desde: 09/30/13
548 Reputação
Autoria de 3 guias
Equipe
Cal Poly, Team 14-10, Forte Fall 2013 Membro de Cal Poly, Team 14-10, Forte Fall 2013
CPSU-FORTE-F13S14G10
Membros da 4
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 20
Duração total: 2,008
