Ir para o conteúdo principal
HP Pavilion DV3 Hard Drive Replacement
O que você precisa
  1. HP Pavilion DV3 Hard Drive Replacement, Battery: passo 1, imagem 1 %32
    • Step 1 – Battery: Locate the battery release slider on the bottom of the laptop and move it in the direction of the arrow to the unlock position.
    • The yellow highlighted edge of the battery should pop up slightly when the switch is moved
  2. HP Pavilion DV3 Hard Drive Replacement: passo 2, imagem 1 %32 HP Pavilion DV3 Hard Drive Replacement: passo 2, imagem 2 %32
    • Step 2: Using the edge of the battery that has popped up, lift the battery out of the computer.
  3. HP Pavilion DV3 Hard Drive Replacement, Hard Drive: passo 3, imagem 1 %32
    • Locate the screw for the hard drive cover (The cover has HP ProtectSmart written on it).
    • Remove the 3.5 mm diameter, 7 mm long screw with your Phillips PH1 screwdriver.
    • The screw will remain attached to the cover.
  4. HP Pavilion DV3 Hard Drive Replacement: passo 4, imagem 1 %32 HP Pavilion DV3 Hard Drive Replacement: passo 4, imagem 2 %32
    • Grab the raised edge of the cover lift up. This will separate the cover from the laptop.
    • Put the cover and screw to the.
    • This will reveal the hard drive.
  5. HP Pavilion DV3 Hard Drive Replacement: passo 5, imagem 1 %32 HP Pavilion DV3 Hard Drive Replacement: passo 5, imagem 2 %32 HP Pavilion DV3 Hard Drive Replacement: passo 5, imagem 3 %32
    • With your fingers, grab the clear tab.
    • Pull right first, and then upwards (towards you).
    • The hard drive should slide out of place and detach from the laptop.
Conclusão
5 outras pessoas executaram este guia.
Luke Whitmarsh
Membro desde: 09/30/13
649 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team 14-10, Forte Fall 2013 Membro de Cal Poly, Team 14-10, Forte Fall 2013
CPSU-FORTE-F13S14G10
Membros da 4
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 11
Duração total: 4,985
