Ir para o conteúdo principal
HP Pavilion DV3 HP Pavilion Wireless Card Replacement
O que você precisa
  1. HP Pavilion DV3 HP Pavilion Wireless Card Replacement, Battery: passo 1, imagem 1 %32
    • Step 1 – Battery: Locate the battery release slider on the bottom of the laptop and move it in the direction of the arrow to the unlock position.
    • The yellow highlighted edge of the battery should pop up slightly when the switch is moved
  2. HP Pavilion DV3 HP Pavilion Wireless Card Replacement: passo 2, imagem 1 %32 HP Pavilion DV3 HP Pavilion Wireless Card Replacement: passo 2, imagem 2 %32
    • Step 2: Using the edge of the battery that has popped up, lift the battery out of the computer.
  3. HP Pavilion DV3 HP Pavilion Wireless Card Replacement, Wireless Card: passo 3, imagem 1 %32
    • With the laptop upside down, locate the three screws on the wireless card cover and unscrew the screws.
    • All three screws will have a 3.5 mm diameter head.
    • Two of the screws will be silver, 7mm in length, and will stay attached to the cover.
    • One screw will be black, 13mm in length, and will separate from the cover. Set this screw aside.
  4. HP Pavilion DV3 HP Pavilion Wireless Card Replacement: passo 4, imagem 1 %32 HP Pavilion DV3 HP Pavilion Wireless Card Replacement: passo 4, imagem 2 %32
    • Grab one of the edges to the cover and lift up (towards you).
    • Set the cover to the side.
    • The wireless card will now be exposed.
  5. HP Pavilion DV3 HP Pavilion Wireless Card Replacement: passo 5, imagem 1 %32 HP Pavilion DV3 HP Pavilion Wireless Card Replacement: passo 5, imagem 2 %32 HP Pavilion DV3 HP Pavilion Wireless Card Replacement: passo 5, imagem 3 %32
    • Using your hand, pull the black and white antenna wires upwards.
    • This will disconnect the antenna wires from the card.
  6. HP Pavilion DV3 HP Pavilion Wireless Card Replacement: passo 6, imagem 1 %32 HP Pavilion DV3 HP Pavilion Wireless Card Replacement: passo 6, imagem 2 %32
    • Locate the two black screws connecting the wireless card to the laptop. They will have a 3.5 mm diameter head and be 4mm long. Remove the screws.
    • Once the screws are removed, the wireless card will pop up.
  7. HP Pavilion DV3 HP Pavilion Wireless Card Replacement: passo 7, imagem 1 %32 HP Pavilion DV3 HP Pavilion Wireless Card Replacement: passo 7, imagem 2 %32
    • Grab the sides of the wireless card and pull it up and to the left to disconnect from the laptop.
Conclusão
Uma outra pessoa concluiu este guia.
Brandon Baldovin
Membro desde: 09/30/13
548 Reputação
Autoria de 3 guias
Equipe
Cal Poly, Team 14-10, Forte Fall 2013 Membro de Cal Poly, Team 14-10, Forte Fall 2013
CPSU-FORTE-F13S14G10
Membros da 4
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 16
Duração total: 1,649
